Results 1 to 7 of 7
    May 26 2014
    Canton, MI
    C7 A6 3.0T Adjustable Upper Control Arms
    I have H&R Street Springs on my C7 A6 and recently I've beem getting some tire noise due to inside tire wear from to the negative camber.
    Does anyone know of any adjustable upper control arms for the C7 A6?
    Thanks
    Registered User Four Rings XLR8 Craig's Avatar
    Feb 14 2014
    Audi's
    Branford, CT
    SPC makes them, we have them here on our website. Add quantity (2) to your cart if you want to do both front. Each kit is for one side.
    http://vag.excelerateperformance.com...i-2247860.aspx
    These use an OE style joint, so no reduction in comfort or ride quality. We use these on every Audi we do here for the most part.
    Thanks,
    Greg
    Mar 18 2011
    Chicago SW Suburbs
    Doesn't have A6/S6 fitment listed, but they do fit the C7 A6/S6?
    2013 S6 Estoril, Innovation, LED, Carbon, Roc-Euro, EPL Stg 1
    Veteran Member Four Rings saxon's Avatar
    Oct 16 2012
    pa
    I've never seen any issue without camber kits, are you sure it's not wear from toe?
    Current Ride- 2018 Audi RS3 Glacier White
    Unitronic- 10.0@136mph race prepped
    10.5@133mph winter tires full street prep
    Past cars 2010 s4-2012 Nissan GT-R -2014 S6-2016 s3-2015 M3--2011 b8 s4
    Veteran Member Four Rings RedS-line's Avatar
    Mar 19 2008
    2019 S5, 1990 944 S2
    BUMP since A4 S4's question wasnt answered. Im deciding between the SPC ones and Eurocodes, but the e-code ones are cheaper since you need to order 2 of these to do the front. E-code also advertises +- 3 degrees vs +- 1.5 degree camber adjustment.
    DOES ANYONE have either? how are they?
    2019 S5 BO.SS
    1990 944S2 Cabriolet
    2009 R8 6 Volt :)
    Veteran Member Three Rings jrsAudiA6's Avatar
    Oct 11 2011
    2018 A5 SB
    Riverside, California
    Quote Originally Posted by AA S4 View Post
    I have the SPC upper adjustable control arms. I have mine adjusted for a -2 deg. camber.
    2018 A5 SB Matador Red Premium Plus
    2012 A6 Garnet Red, Prestige Pkg, Innovation Pkg, B&O, 20" Sport Pkg, H&R RSS + Coilover, Alcon Mono6/380mm front brakes, S6 rear rotors(356x22mm)/caliper carriers.
    034 DL fr suspension arms, 034 Track DL engine mounts, Eurocode Front and Rear sway bars & Alu Kreuz front brace, 034 ECU/TCU tune, DP PR 3.11, JHM Hx
    CTX 50% Tint F. S. Windows, CTX 30% Tint R. & R. S. Windows, 3M Pro PPF, hood, L & R fenders, AWE Exhaust w/o down pipes
    Sep 10 2015
    VA
    Quote Originally Posted by saxon View Post
    My alignment was out quite a bit after lowering. Think it was 2degrees out in the rear and 1.6 in the front and I only lowered about 25mm. Car handles much better after installing them and getting them set up. Car feels much better steering into corners now and also tracks better with improved steering feel.
