Results 1 to 12 of 12
    Established Member Two Rings CT-audi-S4's Avatar
    Nov 14 2016
    Snow tire wheel fitting
    I have a 2013 S4 (B8) and I currently run the stock 18" wheels that came with the car (P245/40R18). I want an additional set of rims for mounting winter tires (need those here in CT) and I found a good deal on a set of used 17" rims. I have searched this forum and some other Audi specific sits and I am getting confliting information. Maybe folks can help me settle this out.
    Current setup:
    245/40R/18
    width: 8
    offset: 47
    Possible new setup:
    225/45R/17
    width: 7.5
    offset: 45
    Nov 18 2014
    Jersey
    I have Stock size R2's on Stock 19's. Thing is BEAST
    2018 Jeep GC Trackhawk
    2022 Audi SQ7
    2017 R8 TT. 1370whp.
    2007 Porsche 911 Turbo...Bolt On's
    Veteran Member Four Rings The Fat Kid's Avatar
    Mar 10 2015
    New England
    Did you accidentally end up searching in the A4 section? I am pretty sure 17" wheels will not fit over the S4's brakes; just look at the gap with your OEM 18" wheels.
    Oct 14 2012
    Empty...for now...
    SE PA
    I am not sure that a 17" wheel will fit over the front brake caliper. If I remember correctly, the balance weights on my 18" winter set almost scrape the brake caliper.
    SOLD 2015 Daytona Gray S4
    Jan 02 2011
    2018 4M Q7, 996 Turbo, 2014 Q5 3.0T
    MN
    Quote Originally Posted by SteveYem View Post
    There are a select few 17's that do fit on the S4...but 18's do for sure so it's easier to just go with 18.
    I run a 18" setup with 235/45 R18 tires for winter.
    2018 Audi Q7 3.0T: Glacier White Metallic/Black, Prem +, Driver Asst. Pkg, Vision Pkg, 20" 10-spokes - Dadwagon 3.0
    2014 Audi Q5 3.0T: Moonlight Blue/Black, S-Line, Sport Interior, Nav, Adv Key, VAG-com's, 034 Intake tube Wife's Daily Driver - Momwagon 3.0
    2001 996 Turbo: Black/Black, Tip, Diamond Black BBS RS-GT's - Summer Car
    Mar 21 2015
    Throw winter tires on those factory 18's and look for some 19's for summer.
    Veteran Member Three Rings Jv218's Avatar
    Jun 10 2015
    15 S4, 2012 civic
    Boston
    I run a 225 on my stock 18
    15 Ibis white, Dsg, P+, magma interior, F1 35% pinnacle tint, ECS RS4 grill, AWE Track 90mm tip, 19x9.5inch HRE FF01, ECS Carbon Intake
    Veteran Member Four Rings MVR 155's Avatar
    Apr 04 2013
    2018 Audi S6, 2015 GMC Yukon Denali and 2002 Corvette Z06
    Bartlett, IL
    Best advice right here!! As mentioned above, there are a couple of 17" wheels that may fit the car but locating such a set may prove to be difficult. I would use your stock 18's for winter duty, no offense but the factory 18" wheels do the car no justice so allocating them for winter wheels is a good choice. Buy a set of nice 19" wheels or find a set of factory (peelers or rotors) that were take offs or that someone upgraded from. Run some nice summer rubber such as PSS's on those and throw some nice winter tires on your 18's, you'll have the total package then!!!!
    2018 S6 Prestige, Glacier White/Black, S-Sport, Driver Assistance, Black optic, Carbon inlays, Cold weather, Vorsteiner VFF 103's in carbon graphite.
    2002 Corvette Z06
    Apr 04 2012
    MSP
    This ^^
    Quote Originally Posted by AudiDTMA4 View Post
    Most 17's will not fit. I would not take the risk unless you can test fit them before committing to the purchase (wheel and tire).
    Go with 18's. If you don't want to use your stock 18's for winters then buy a second set of 18's. Tirerack has a ton of options at reasonable prices.
    Oct 05 2015
    Rye, NY
    Perfect timing. I just listed these this morning and I'm in Westchester.
    http://www.audizine.com/forum/showth...EM-Winter-Mats
    Veteran Member Four Rings pdqgp's Avatar
    Mar 06 2015
    a 12 Second boat, & Wife's Lincoln
    Columbus, Ohio
    ^^ this absolutley. I wouldn't even think about keeping 18's on mine full time. Blah...
    Get the winter rubber mounted up and take your time shopping for summer goods. You'll thank us later. Having dedicated summer only is oh-so nice. Cost is a little more up front but well worth it in the long run.
    2018 Midnight Black Metallic AWD Infiniti Q50S Red Sport | Burger MS JB4 | 395awhp/430awtq
    2018 Ruby Red Metallic Lincoln MK-C Reserve | AWD 2.3l EcoBoost - Wife's
    2014 Brilliant Black S4 | S-Tronic | 187mm APR Stage 2 Dual Pulley & APR TCU Tunes | APR CPS - SOLD
    Jun 21 2004
    mpls, mn
    225/45/18
    If you found a 17 that fit, 225/50/17
