Results 1 to 8 of 8
    Veteran Member Four Rings nnnick's Avatar
    Nov 01 2005
    2006 S4 6MT
    La Jolla, CA
    B7 A4/S4/RS4 Carbon Fiber Vented Hood Painted Brilliant Red
    I'm beginning to part out my S4 (which is for sale here: http://www.audizine.com/forum/showth...o-chain-rattle) and am offering my aftermarket hood for sale. It is made by VIS/Aerofunction using the old Vorsteiner design/mold after they stopped producing it. Further details of this hood can be found here: http://nickscarblog.com/reviews/b7-a...y-aerofunction. It cost over $1000 new and I spent almost $800 on body work to make the vents functional, add foam for rigidity, and paint/clear coat. If your car is Brilliant Red, this can be installed in 5 minutes using the OEM mounting hardware. If your car is a different color then you can just have the carbon masked off and have the rest of the hood repainted whatever color you like - the bottom side is flat black so it should be cheap to just paint the top side. Looks awesome and I get compliments all of the time, definitely adds an aggressive look without being over the top. It is INSANELY light, a good 30+ lbs weight savings over OEM, and functional cooling help keeps IAT down too. The hood has a few minor rock chips from daily driving but no major issues. Only selling it because I'm taking the car back to stock and selling...
    Looking to get $800 obo, local buyers only...I will NOT ship.
    Mega gallery here: https://www.flickr.com/photos/nickro...57632163415397
    IMG_9667 by Nick Roshon, on Flickr
    Aerofunction Audi S4 Hood by Nick Roshon, on Flickr
    Current: 08 R8 6MT, 14 Cayenne GTS, 98 Saleen XP8
    Past: B7 RS4, '12 Audi TTRS BT Build | 2006 Audi S4 HPDE Build | 2006 Audi A4
    Visit my blog: NicksCarBlog.com
    Established Member Two Rings slineb7's Avatar
    Jul 16 2010
    2016 Escalade EXT, 2017 A8
    Tampa
    That's a beautiful hood sir. GLWS. Decided against the hood pins though? Any risk there?
    2007 RS4 Daytona Gray | KW V3 | More to come...
    Nov 01 2005
    2006 S4 6MT
    La Jolla, CA
    Quote Originally Posted by slineb7 View Post
    I'm sure there is a risk, but I've had the hood for four years and haven't had an issue...including several track days, and a few high speed runs (professional driver, closed course, don't try this at home kids). I'd still recommend them, and so does the manufacturer, but you should be pretty safe. The expanding foam in the hood added a little weight and rigidity, and the real trick is making sure you have it aligned correctly.
    Jul 16 2010
    Tampa
    Quote Originally Posted by nnnick View Post
    I appreciate the detailed reply, and again GLWS. If I wasn't buying every mount for my ride I'd seriously debate hopping on this. Nicely done.
    Senior Member Two Rings jrow26's Avatar
    Apr 01 2016
    2007 Jeep Wrangler 4door
    GA
    Where are you located ?
    Nov 01 2005
    2006 S4 6MT
    La Jolla, CA
    Quote Originally Posted by jrow26 View Post
    La Jolla/San Diego
    Apr 01 2016
    GA
    Damn I'm not local to you.....
    Veteran Member Four Rings Pat_McGroin's Avatar
    May 09 2010
    Downey Ca
    This won't last long, wish it was in the budget, otherwise I'd be all over it! GLWS.
    Rick
    B5 S4 StageIII
    Sold:Brilliant Black 2008 S4 Avant Tip.
    Gone but never gottin - Ibis 2010 A3 2.0T
