I just got my pistons out of the block :) Now, I have most items I need in the mail. Looking at all of my organized parts in empty Immortal IPA beer boxes .. I do not see a gasket from the upper oil pan gasket. The gasket looks like it was a white silicone material. Does this need a gasket or special Silicone? Also, what do I torque the bolts to on this piece? This "Piece" is the 2 inch thick piece that sits between the lower engine block and the oil pan. I had to remove it to access the rod bolts, not sure exactly what it is called.
Thank you all for the help!
