Results 1 to 26 of 26
    Oct 28 2012
    near chicago
    2013 s6 launch control
    Read as much as I could find but I can't seem to get lc to worked. Sticks at 2k and loads trans. Tried three time exactly as described and no luck. Did more searching and checked launch control counter and it's at 1. Ideas?
    http://youtu.be/DNUNE6BZNm8
    Mar 29 2014
    Hampshire, UK
    You have to hit the various buttons to disable ESP etc. Put into D, pull down for S mode, stand on the brake then floor the accelerator (it will stick at around 5000 revs steady no matter how much you push the accelerator), then step right off the brakes pedal and hang on!
    The trick is to use both feet - one on brake, other flooring accelerator pedal - like a racing driver. Its not a natural movement if you've not one it a few times.
    From your vid clip it looks like you just floored the pedal. Thats not LC.
    2016 S7 Sepang Blue ///Matrix//Bose//Self Park//Lane Assist//ACC//F&R parking cams//Blackvue DR750//Phone Box//Sunroof//Privacy glass//Carbon mirrors//Neidfaktor Steering wheel//RS Knob//OEM RS Grill//Suntek PPF//De-chromed//Modded Exhaust//Cete ASC v2 installed//APR Stage 3 w/RS7 Turbos and intake pipes + TSU//Eventuri CF intake//Carbon Diffuser
    Gone: 2014 Audi A7Q 3.0 TFSI
    Gone: 2011 Audi A6Q 2.8 TFSI
    Veteran Member Four Rings zcd2.7t's Avatar
    Jan 19 2010
    MI/CA
    If stability control isn't turned off, or if the car isn't in "Dynamic" mode with the trans in "S", then LC WONT engage.
    When properly engaged, the engine isn't straining against the brakes - it revs freely, just like if the car had a manual transmission and the clutch was depressed.
    2022 Tesla Model 3 Performance
    2023 Genesis GV60 Performance
    2015 Q5 TDi - Torque, baby!
    (Gone) 2013 S6, Glacier White over Black.
    (Gone, never forgotten) 2011 S4 Prestige S-tronic wSTaSIS stuff
    Oct 28 2012
    near chicago
    I guess in that clip stability control wasn't off. But, today, I made sure. Dynamic, put into drive then click shifter down once to go into sport, push brake pedal all the way (hard) and hold to floor, then floor gas pedal. Still didn't work and I tried it three times.
    Jan 19 2010
    MI/CA
    Post a clip of the entire procedure you're using to try to engage LC mode so that we can try to help you figure out what's going wrong.
    Oct 28 2012
    near chicago
    Ok. I'll see if I can tomorrow. Watch, I'll do it step by step for the clip and it'll work
    Jan 19 2010
    MI/CA
    Quote Originally Posted by slowguy View Post
    Most likely, yes...😉
    Established Member Two Rings ///S6///'s Avatar
    Sep 07 2016
    Toureg and Bug (Kids cars)
    St Charles, IL
    Haha!! I have been doing it wrong this whole time also.. just got back from dropping off the mother in law and had to try it out, what a difference!! Had to let off a bit cause it started going sideways...lol
    Bill
    2017 S6::Sepang Blue::Black Optics::Prestige::Night Vision::Drivers Assistance::Cold Weather::Comfort:: Stage 1 EPL :: Roc Euro:: 25% Tint ::
    2015 SQ5 (Wifes Car)::Mythos Black Metallic::Black Optics::Premium Plus::Technology::21" Wheels
    Veteran Member Three Rings Dguth's Avatar
    Dec 14 2011
    Dublin, OH
    If you put it into dynamic and then pulled back on Shifter. You put the trans back into normal mode. Putting it in dynamic automatically puts the trans in sport mode.
    2014 S6 | Glacier White | Prestige Package | B&O Sound | Tinted & Lowered | APR Stage 1.1 Tune | APR TCU Tune | XPEL Front | Flat Bottom Steering Wheel | Soon to be installed: RS7 Turbo, RS7 Intake, AMS Coolant Upgrade, AMS High Flow Downpipes, RS6 Grill and APR Stage 3 Tune
    Jan 19 2010
    MI/CA
    Quote Originally Posted by Dguth View Post
    Excellent point, and absolutely correct!
    Veteran Member Four Rings 4RCFED's Avatar
    Aug 27 2014
    12' Audi S4 (sold), 18' Discovery HSE (V)
    Sandy Springs, GA
    Maybe the car is at its max launch counter(200)?
    2012 S4 (sold)
    Jan 19 2010
    MI/CA
    Quote Originally Posted by 4RCFED View Post
    Newp:
    ...Did more searching and checked launch control counter and it's at 1. Ideas?...
    Senior Member Two Rings mwmaroney1's Avatar
    May 08 2012
    2014 S6
    I had problems initially as well but got it down now. After making sure your car is set up right (sport mode, esp/acc etc turned off) then I've found starting with using just one foot works good. Roll to the point you want to start at ensuring your steering wheel is absolutely straight, it will not engage with wheels turned. Take your foot off the gas and stop like normal with the right foot on the brake now and ensure you press it hard to the floor and hold it down. Now apply your left foot keeping it in place hard against the floor and then use your right foot to floor the gas to the floor as well. Again when this is done correctly there is no extra strain on your brakes after the gas is pressed. If you're feeling any brake resistance the sequence has not been done correctly. This is the method I ensure to use and have no problems, used to be hit or miss when I would start off trying to use both feet stopping with left (maybe I just sucked at it). Good luck!
    Nov 18 2016
    I also have a 2013 and still can't get it. I don't know my count number, but if you get it, report back with some more info.
    Oct 28 2012
    near chicago
    With any luck I'll try again this afternoon. I did check my counter (very easy in VCDS) and was at "1". I assume this is because I recently had the TCU software flashed. I swear I did all the steps previously mentioned but I must have done one little item incorrectly. I'm now wondering if the wheels weren't 100% straight but it sure seemed they were. Other thing is (and I know traction control is no deactivated in the video, I did fix that on subsequent tries), is that I am sure it was is sport mode. I just made sure it said "S" in the cluster. My last guess, if it still doesn't work tonight, that maybe because I have a drivetrain mount code, this is disabling it? No codes in ecu or tcu, just that single drivetrain mount code.
    BTW, real easy to check the counter if you have VCDS. Go into autotrans module, advanced measuring blocks, type in "launch" in the search box. Find the launch control counter and check the box.
    Sep 19 2014
    Newcastle
    Turn off hill break too
    Sent from my XT1580 using Tapatalk
    Audi S6 C7.5 Avant 2016 Sepang Blue APR Stage 2, Custom Downpipes, Revo RS Intake, X-Pipe & Resonator Delete - 441WHP 528WTQ 551BHP 660 LB FT.
    Jan 19 2010
    MI/CA
    ...My last guess, if it still doesn't work tonight, that maybe because I have a drivetrain mount code, this is disabling it? No codes in ecu or tcu, just that single drivetrain mount code....
    Seems logical, at least, that that code could disable LC, given the shock that LC puts through the drivetrain. Sounds like you might have a bad/leaking motor mount? (not unheard of, BTW)
    Mar 30 2015
    Denver
    And one final suggestion. I believe I've read that the car has to be 'up to temp' for LC to work as well. So it won't LC unless you've driven it for a bit first. But I'd guess the most likely culprit is the code you've thrown.
    2013 S6 - Estoril Blue - Lunar Silver
    Established Member Two Rings turbello18's Avatar
    Nov 12 2010
    08 Q7 Sline
    Manchester
    Temp needs to be up and steering wheel needs to be straight.
    '13 S6
    Jun 18 2011
    markham, ontario
    I also find LC on the 2013 S6 is very difficult to engage but not impossible - this is compared to my B8 S4 which was very easy to engage.
    Couple of things I tried initially might have helped. One is the DSG calibration procedure which is done after a flash. Basically it adapts the engagement point etc.
    I also really needed to floor the brake, you pretty much have to come off the seat to do this. Then, pause a nice full second, then engage throttle.
    23 BMW X3 M Competition Brookyn Grey, 17 Golf 1.8 TSI Pure White
    -Traded-in-
    19 RS3 2.5T Nardo Grey, 18 Golf R DSG Indium Grey, 13 S6 4.0T DSG Phantom Black, 11 Golf 2.0TDI DSG Candy White, 11 S4 3.0T S-tronic Ibis White, 10 Q5 3.2FSI 6A Ibis White, 01 Golf GLS 1.8T 4A Black, 06 A3 2.0T DSG 6A Brilliant Black, 04 A4 1.8TQMS 6M Ocean Blue, 00 A4 1.8TQMS 5M Light Silver, 99 Golf GL 2.0 5M Candy White
    Veteran Member Four Rings MadAboutCars's Avatar
    Aug 27 2015
    MY18 Audi RS6 P, MY18 Audi SQ5,MY16 Audi S6 (sold), MY12 Audi Q7 4.2L TDI S-line (sold)
    New Zealand
    I think I read somewhere that you also have to have a reasonable amount of gas in the tank, for LC to work.
    2018 Audi RS6 Performance - Floret Silver, Titanium styling package, 21" titanium 5 V spoke wheels, Dunlop SP Sport Maxx GT 285/30/21, Black sports seats, Carbon inlays, Sports diff, Sport exhaust, Matrix LED headlights, 360 camera, Head up display, Active lane/side assist with adaptive cruise control, Park assist, Privacy glass, Electric tailgate with foot open
    Mods: Dura-Seal exterior/interior, Audi Sport door lights
    Jan 19 2010
    MI/CA
    So, what finally happened?
    Oct 31 2005
    Ashburn
    Just like the OP i've had the same issue on mine so I'll add whatever might be helpful. I Launched it several times on the street no problem. Took it to the track and that's where the problem started. It's hard to expalin a issue that majority of the board members dont have so the inital respose is your doing it wrong and a list of How to use LC pop up.
    I also scanned the car and got this code, couldn't find much on it. Cleared it and it never came back but car still responds in the same way.
    A buddy of mine and Ex-Audi tech mentioned to me to make sure the car is up to date on all maintenance's and that the DSG tranny is high Maintenance etc.
    Long story short, I just happened to find out my car never received the 35k service which is a major service. Since this should have been done already since my car was CPO'd at 37k miles Audi has agreed to do the maintenance free of charge or course since they claimed it was up to date.
    As of yesterday the car is back to stock. I'm driving it around and maybe tomorrow or sometime during the week I will test LC a few times to see if any issues arise and report back. Also the car goes in for service on Monday, so I'll see if there a difference in how it drive and shifts.
    - Instagram: @Sinister_rs5-
    Veteran Member Four Rings gk1's Avatar
    Aug 06 2014
    NJ->CO
    I had the same code after my TCU tune. Never came back. Just figured it had something to do with that. However I do not have the launch control issues you have. Hopefully the trans fluid change helps.
    2023 e-tron GT Daytona Gray
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    2014 SQ5 Glacier White
    2012 S4 S-Tronic Monsoon, Stage II [email protected] 4275lbs
    2008 A6 3.2Q S-Line Daytona
    2007 A4 2.0T S-Line Ice Silver
    2001 S4 Nogaro Blue, Stage I [email protected] 3944lbs
    Oct 31 2005
    Ashburn
    Quote Originally Posted by gk1 View Post
    Could have been the case, I never scanned the car after the TCU tune until LC wasn't working correctly. But it hasn't come back, I hope it helps too as this is def frustrating.
