Results 1 to 18 of 18
    Senior Member Two Rings BryMFL's Avatar
    Apr 20 2007
    '02 Audi 1.8T Quattro
    Winter Haven, FL
    standard parasitic draw
    I have an 02 a4 1.8 m and was wondering what a "normal" amount of parasitic draw is for our cars after setting for 5min or so (enough for all electronics to tuen off)?
    Currently i have .05ish once the car is all closed up and has sat for 5min.
    My battery dies after a day or so sitting even though i had the battery tested and the alternator. I think maybe they didnt test the battery or alt correctly.
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    That is a really interesting question! I have an OEM battery that is a little less than two years old. Here is my voltage at idle:
    Here it is when I turn the key off:
    And here it is after 5 minutes. I should note that I have an ELM327 Bluetooth transmitter that I leave plugged in all the time.
    Apr 20 2007
    Winter Haven, FL
    Thanks old guy but im actually looking for the amp draw. Disconnect the negative cable and put each meter lead on one of the negative post and one on the negative cable to see what the car is drawing during "off" mode. Most cars have anout .05 to my research. Thats why alot of cars battery goes dead after a month or so not being started.
    Apr 20 2007
    Winter Haven, FL
    Oh and putt the multimeter on the "A" on the red side and move the red wire over the the other red post spot that says for 10amp or maybe 5 for yours
    - - - Updated - - -
    How do oyu attach photos. Im in the mobile site?
    Veteran Member Four Rings jygesq's Avatar
    Aug 22 2014
    1986 Honda CH 150 D scooter bought new
    bloomfield,ct
    the shut off is 12-15 minutes, not five
    2015 S4, P+, Florett Silver,black /silver nappa leather, S-tronic ,sport diff,B&O ,tech package ,supercharged badges. All season tires ,cargo net, factory dip stick
    Apr 20 2007
    Winter Haven, FL
    Quote Originally Posted by jygesq View Post
    Ok thanks
    Sent from my SAMSUNG-SM-N920A using Tapatalk
    "BryMFL"
    Bryan Meeks
    "Quattro- It's like having your very own roller coaster ride!"
    Apr 20 2007
    Winter Haven, FL
    Nevermind figured out pics, see below.
    "BryMFL"
    Bryan Meeks
    Dec 28 2006
    Western Maryland
    [IMG][/IMG]
    Jan 24 2010
    Paramus,NJ USA
    Best way to find out what yoru draw is with a amp clamp and a dvom thats setup for one.From what I know according to audi a draw above 0.030 amps is considered high.That being said the car goes to sleep completely after about 20mins.If your looking to check draw you can latch the hood latch and the drivers door.Then you can start looking at the meter and check what you the draw is.Once your certain you have a draw you can start pulling fuses one by one.Looking at the meter after a fuse is removed.When the value drops.Youve found your draw.From personal experience with b6's.Ive had the radios draw some power and the power seat buttons draw some power if they were jammed or stuck in a position.If you have water in the car then the comfort module could be drawing a good amount of power as well.
    Ziddy Autowerks
    Dec 28 2006
    Western Maryland
    give me a few minutes and I will check the draw again. The last pic was after 5 minutes.
    Apr 20 2007
    Winter Haven, FL
    Mine was the .05 after a much much longer time than 20min with the only thing open was the hood.
    There are some relays that don't run through the fuse panel. Any ideas where to start? Isn't the relay fuse box under the wiper cowl?
    "BryMFL"
    Bryan Meeks
    Dec 28 2006
    Western Maryland
    All systems shut down for at least 30 minutes and I unplugged my ELM327 Bluetooth transmitter:
    Apr 20 2007
    Winter Haven, FL
    Im putting my battery on charge overnight and testing again tomorrow. I just went through this in my work truck last week and found a bad glow plug relay pulling 2.5amps and killing brand new fully charged batteries in less than 20min.
    "BryMFL"
    Bryan Meeks
    Apr 20 2007
    Winter Haven, FL
    Good call i do have a bluetooth scanner in.....
    "BryMFL"
    Bryan Meeks
    Jun 29 2014
    America
    Broken glove box hinge may cause the drain, I had that happen. Not that there aren't other things that can be an issue.
    Apr 20 2007
    Winter Haven, FL
    Ok. Got it down to a little draw from the cigarette lighter socket and fuse 13 steering column module. The module controls pretty much every switch and button in the car. This might take awhile to pinpoint. Any suggestions?
    "BryMFL"
    Bryan Meeks
    Veteran Member Three Rings tHatOne guY's Avatar
    Aug 20 2012
    06' Yamaha R1...Raven
    Mesa, Az
    Try unplugging the suspect components or the fuse for them and watch your meter.
    Went through this whole parasitic draw dance with my B6 a few months back
    Apr 20 2007
    Winter Haven, FL
    Still having this problem. The major draw is coming from the steering column module. Could someone post a list of what runs through this?
    "BryMFL"
    Bryan Meeks
