    May 25 2016
    Power Dip When going from 1st to 2nd?
    Tuned with ED Stage 1.5 plus their dsg tune with the comfort setting on
    So when I'm in sport mode and I mash the gas to go quick, after the initial 1st gear pull, when switching to 2nd, there is an abnormally large decrease in power when shifting, Like a pause, then it shifts to 2nd and the rush of power comes back on. Is that normal? Only happens when hammering the gas in sport mode. Thoughts?
    May 25 2016
    I'm thinking maybe it could be the traction control?
    Veteran Member Four Rings HurrayFive's Avatar
    Jul 21 2013
    Remote
    Traction control + the soft rev limiter for sure. Before I had the APR DSG tune but was still stage 2, mashing the gas in 1st with traction control on resulted in traction control killing the fun on the shift to 2nd + the car hitting the factory soft rev limiter which cuts fuel for a split second. After their DSG tune I turned on the RS style hard limiter, so if I forget to turn off traction control it smacks the limiter with a satisfying 'pop pop pop' as it shifts to 2nd.
    I (try to) always put the traction control in at least Sport when I start the car, doesn't happen then cause the car doesn't care that it's losing traction if you gun it in 1st.
    '25 M8 Comp GC Frozen Tanzanite on Ivory/Night Blue - 11.0 @ 126 bone stock
    May 25 2016
    Thanks for the reply. It makes a lot of sense and is probably what is going on.
    Junior Member Two Rings The_Kracken's Avatar
    Sep 29 2016
    2015 S3; 2012 Q5 ; 1997 Chevy Tahoe
    San Jose, CA
    I experience this frequently in my 2015 S3 with APR stg 1 and DSG tune, mostly when turning and accelerating from stop. Turning off traction seems to stop it
    Sent from my XT1096 using Audizine mobile app
