Results 1 to 31 of 31
    Established Member Two Rings sixoclub's Avatar
    Jan 02 2013
    2011 Jeep Cherokee
    Northern California
    Which is better in the west coast snow?
    Which is better for transporting the family in the West Coast snow-
    1. 2013 stage 2 S4 with sports differential, manual transmission and Blissak snow tires
    or
    2. 2017 Subaru Outback with 3.6R engine and stock tires?
    Nov 03 2016
    Range Rover HSE, Range Rover Sport HSE
    Los Angeles, California
    Gosh this ones a tough question cuz tires are very important in snowy conditions. What brand of tires are on the subie? Cuz some all seasons have good ratings in snow
    Jan 02 2013
    2011 Jeep Cherokee
    Northern California
    The Subaru has Bridgestone Dueler H/P tires.
    Mar 25 2015
    Calgary
    Outback has more clearance, but id choose the car with winter tires any day.
    Veteran Member Four Rings Dr GP's Avatar
    Jun 08 2005
    Lexus RX 350
    SE, PA
    Dedicated snow tires will perform better in snow than almost any all season tire. The difference is the tires not the car. BTW, is west coast snow any different from snow from other areas?
    Jan 02 2013
    2011 Jeep Cherokee
    Northern California
    I was thinking the Audi as well due to the tires. Not a bad position to be in having to choose between the two.
    Jan 02 2013
    2011 Jeep Cherokee
    Northern California
    One fear of mine (justified or not) is bottoming out on the snow and damaging that unprotected differential.
    Veteran Member Four Rings Zach L's Avatar
    Feb 24 2010
    Austin, TX
    Not your question, but relevant if you're in the market... A week after one of my clients bought a new Subaru Outback, he said it was a great car. Six months later I asked him if he was still enjoying it and he said he had sold it back to the dealership after only two months of ownership. Said it was the most boring car he'd ever owned/driven. Reliable and ergonomic, but flat boring. Went and bought a Mini Countryman. I personally have never driven one of the newer Outbacks, so I can't comment myself.
    As others have said, when comparing two AWD cars, snow performance will come down to tire choice.
    Daily Driver: B8 A4 quattro 6MT, Aruba Blue on Black, Premium Plus, Sport Package, Bang & Olufsen
    Current Projects: 2006 Cayman S 6MT • 2006 VW GTI 2.0T 6MT • 1997 VW Golf • 1982 VW Rabbit Diesel • 1972 VW Bay Window Bus
    Nov 23 2014
    '05 infiniti G35 coupe, '12 B8 A4 avant quattro
    Socal
    West Coast Mountain dweller here and I have B8 avant and older Subaru legacy wagon (lowered outback). Given your options, I would go with 3.6R outback but I'll get myself a set of blizzak along with it. The flat six engine has nice linear torque curve and having higher ground clearance is a major plus.
    Subaru awd system is pretty bulletproof and you get more space with the outback for your luggage and gears. Fully loaded outback will also come with built in collapsible cross bar and tow hitch. You would be able to put roof box for more storage or snow gear carriage.
    Sent from my ZTE A2017U using Tapatalk
    Apr 05 2016
    Portland, OR
    West coast snow, assuming PNW is usually wetter than other places of the country if that makes sense.
    @OP, as long as you're not slammed you shouldn't have issues bottoming out the S4 unless you do some serious off roading
    Feb 24 2010
    Austin, TX
    Quote Originally Posted by whiped View Post
    x2
    Wetter = heavier. Not light and fluffy, but thick.
    Jan 02 2013
    2011 Jeep Cherokee
    Northern California
    Thanks guys for the responses. I used the Audi all last season with Bay Area runs to Tahoe. No issues but then again I didn't have the opportunity to drive on any significantly snowy days. We just replaced my wife's Grand Cherokee with the Outback. She really likes the car but I agree that it is a bit boring of a car for Me to use as daily. We do not have any intention of getting different tires until the stock ones wear out. Even then will stick with all seasons due us driving on pavement 99% of the time.
    Jan 02 2013
    2011 Jeep Cherokee
    Northern California
    I'm sure at some point I will have drive both in snow conditions. I will post when I do.
    Oct 31 2013
    Morris County, NJ
    I'd take a rwd with snows all day long vs an awd on all seasons. Tires make a huge difference. S4
    2011 S4 P+ 6mt | AWE Touring | Roc Euro | H&R OE/Bilstein/034 RSB | APR Stage 2 DP + CPS | TSW Bathurst 19X9.5 | Michelin PSS 255/35/19
    Veteran Member Four Rings s4buckeye's Avatar
    Dec 21 2008
    '23 RS3, '23 S5 Cab and '22 RAM 3500 SRW LTD NE
    Kali
    Quote Originally Posted by sixoclub View Post
    or
    CalTrans will not let you by in R2 chain controls with AWD/4WD w/o "snow tires" per their regs. that is not to say that is the same from checkpoint to checkpoint, etc.
    "snow tires" many times may just mean a M/S tire, etc. i would take the S4 with dedicated snows.
    look at the CalTrans chain control map online. updated all the time.
    “Wanting to be someone else is a waste of who you are.” - Kurt Cobain
    Jan 02 2013
    2011 Jeep Cherokee
    Northern California
    I've always felt Caltrans chain control signs are misleading. R2 requirement signs tend to state the need for 4x4 with chains when in relality it is 4x4 or allwheel drive with a minimum of snow tire. I've never seen an all season tire without a mud and snow rating. The Outback tire has the proper stamp even though it's design is clearly focused for pavement.
    Dec 21 2008
    Kali
    misleading or not, it's their call.
    Nov 23 2014
    Socal
    Quote Originally Posted by s4buckeye View Post
    I frequent mammoth during snow season and I still able to stroll through caltrans checkpoints on my avant w/ stock continental down all season.
    I think most checkpoint officers probably know commonly awd/4wd cars and let them through as opposed to rwd/fwd cars.
    I've taken the avant with same tires to brianhead, Utah and able to do 80s on hwy 5 while it was snowing down quite heavy.
    OP, you will be fine in either car if going to Tahoe would be mostly your route. However you will get more room for your winter gears on the outback albeit its boring driving experience.
    Jun 20 2015
    Lake Tahoe, NV
    As a person who lives in the mountains of Lake Tahoe, I run a B8.5 S4 with Michelin Alpin PA4s on my 19" peelers and it works very well but the ground clearance is a real issue but if you are careful, it's fine. If you enjoy driving, the S4 with snow tires is the way to go.
    Veteran Member Four Rings MrFunk's Avatar
    Apr 04 2012
    MSP
    or
    How are you coming to this comparison?
    Jan 02 2013
    2011 Jeep Cherokee
    Northern California
    They are the two cars in my driveway
    Jan 02 2013
    2011 Jeep Cherokee
    Northern California
    The S4 is an easy choice for me if I'm heading toTahoe by myself or with a friend. The comparison really comes in when going with the family. I have a wife and two young boys. Storage capacity is a small factor but can make due with either. Safety is a bigger consideration.
    Over all I was looking at the two options and wondering which one would actually be the better driver.
    Oct 20 2014
    Reno, NV
    I live in Reno, drive around Tahoe nearly every weekend (beach in the summer and skiing in the winter). I moved from an '02 Subaru Legacy GT with dedicated snow/summer tires to my '11 S4 with Hakkapeliitta's for winter driving. I honestly feel the Subie was more sure-footed in the snow than the S4 is, though the S4 is WAY more fun to drive! I think you WILL lose some sure-footedness with all-season tires on the Outback (driving performance in snow went up considerably when I moved to a dedicated snow tire on the Subie), but as ichigoismyhomie says, the Subaru AWD system is pretty much bulletproof. Put some snow tires on that and I'd chose that every day if it's been dumping or dumping on your way up.
    Senior Member Four Rings
    May 20 2015
    Audi S5 Deep Sea Blue Pearl
    PA
    I'm curious how my DWS 06 tires will do this PA winter. I got through last season fine with pilot sport A/S 3 all seasons that were nearing the end of there life. I mean if it's shitty enough out I just won't go out just because I have a AWD car.
    So far in heavy rain they have been rock solid. Good tires, the revised 06 model for a all season.
    Senior Member Two Rings IceSilverS4's Avatar
    Jan 06 2014
    2012 Audi S4, 2013 Tiguan R-Line
    Blainville, QC, Canada
    I would go S4 because of the snow tires... both cars will have traction, possible problem will be cornering and braking performance in case of an emergency, where snow tire will outperform the all season tires, especially on low temperature and icy condition.
    Sold - 2012 Audi S4 - Ice Silver - Magma Red
    Jun 08 2005
    Lexus RX 350
    SE, PA
    Quote Originally Posted by Vanimal View Post
    I can tell you from experience, that they will do just fine. As long as you don't need to be the first one to the slopes on unplowed roads. Or there is over 12" of new fallen unplowed snow. Been running A/S tires on my S4s since 04 here in SE PA.
    Nov 12 2015
    Here
    or
    Is this a trick question?
    Mein ist grau
    Veteran Member Four Rings SDV325's Avatar
    Jan 20 2014
    Calgary, AB
    Even when I first bought my old 5spd 99 2.5RS it came with average all season Hankook tires, however the thing was unstoppable in the snow. Never had one issue ever on ice or snow. Loved the from and rear viscious LSD's, can rarely remember feeling a loss of traction or even the tires spinning. Then when i put PA3's on it, tank mode
    Now my S4 has shitty sottozero serie II tires, utterly horrible in the winter. so many traction issues just because of the tires. PA4's are on the way for this winter. Im sure it will be a different answer after i get a feel for these tires but Subaru AWD all the way. One thing i noticed different is where my GC had 50/50 power distribution where the S4 is 60/40 i think. Found it can cause the back end to kick out a little too much at times instead of a pure controllable drift in the snow.
    But again, good winter tires on the S4 and all could change.
    2016 Audi SQ5 | Technik | Glacier White | Magma | Black Optics | Beaufort Inlays | Roc-Euro | Revivify Graphene Pro | EPL Stg 2 | Eurocode USS | MOOG Endlinks |
    2014 Audi SQ5 Estoril- STOLEN / RIP
    2015 Toyota Rav4 - Family Wagon
    Jan 02 2011
    2018 4M Q7, 996 Turbo, 2014 Q5 3.0T
    MN
    Tires > everything.
    AWD doesn't help you stop.
    2018 Audi Q7 3.0T: Glacier White Metallic/Black, Prem +, Driver Asst. Pkg, Vision Pkg, 20" 10-spokes - Dadwagon 3.0
    2014 Audi Q5 3.0T: Moonlight Blue/Black, S-Line, Sport Interior, Nav, Adv Key, VAG-com's, 034 Intake tube Wife's Daily Driver - Momwagon 3.0
    2001 996 Turbo: Black/Black, Tip, Diamond Black BBS RS-GT's - Summer Car
    Mar 01 2006
    Kitchener, ON
    Ya tires matter over anything else. Heck I would go as far as saying a S4 /w a performance all season tire < Honda Accord /w snow tires in the snow / ice / slush etc
    Last night we had a nice storm travelling back from Montreal, and the winter tires turned the S4 into a monster, it was so irritating having to be stuck behind people driving 40-60 km/h white knuckling it, while /w my X Ices I felt completely confident in the mess doing 120-130 km/h
    2023 Audi S3 / Stronic // Daytona Grey
    Past
    2018 VW Golf R // 6 MT // Deep Black Pearl
    2010 Audi S4 // Stronic // Phantom Black
    2001 Audi S4 // 6 MT // Light Silver Metallic
    Aug 20 2016
    Plovdiv BG
    S4 for the tyres! Otherwise the Sub with decent snow tyres is really good option! I think ur question is more rhetorical than pragmatical! Greetings!
    Sent from my W6500 using Audizine mobile app
