Results 1 to 8 of 8
    Jul 26 2014
    US
    Tire Size Question
    I'm currently running the 255/30/20s that come with the car stock. For the winter looking to keep the rims on the car but get a 255/35/20 tire with a bit more sidewall. Roads get nasty here in NJ during the winter months. Not lowered and don't plan on it. Anyone running this size? Issues?
    Current: '17 RS3, '13 GTR Black Edition
    Veteran Member Three Rings mossback's Avatar
    Feb 01 2015
    2017 Subaru Outback
    United States
    Your best bet it take the 20" off and get a set of inexpensive 18" wheels and get snows for them in a 245\40-18.
    I have blizzaks on mine, the 18" is the best performance size for the car and they look good too.
    at over 400.00 a tire for Snows in the 20" size it justifies getting a wheel and tire setup.
    2016 TTS
    Veteran Member Three Rings Huey52's Avatar
    Dec 22 2010
    New England
    Excellent advice and I second the motion.
    Quote Originally Posted by mossback View Post
    2016 TTS Sepang blue/rotor gray Tech B&O
    Prior: 2013 allroad; 2011 A5
    Jan 07 2011
    2013 C300 4Matic
    what would you recommend for the wheel specs for that tire size?
    Present:
    2009 Audi S5 Phantom Black
    IG: bknewtype
    Feb 01 2015
    2017 Subaru Outback
    United States
    I am running 18x9 ET45 (offset) the 20" wheels have an offset of ET50,
    Anything with at least a 45 to 50, you don't have to have 9" wide wheels, you run 8, 8.5" as long as the offset is high enough.
    I use this setup as I run my car on the track with them too, and swap out the blizzaks with Trofeo R 265/35 18" in the summer.
    Though you can run 255/40 18" just fine, I pushed the width a little and went 265, and the rubber is way cheaper than 20".
    I think I paid 220 a tire for Bridgestone RE71R and same for Michelin Pilot Super Sports.
    2016 TTS
    Jul 26 2014
    US
    Yeah seems that way. I found a set of all seasons Nitto Neo Gens 245/30/20 for 620 shipped and was debating just leaving them on the car for all time. Otherwise I can get a set from Tire rack and pick up in delaware 18x8s with CONTINENTAL WINTERCONTACT SI in 235/45R18. Little over a 1000 bucks which isn't bad since it includes all hardware to mount.
    Nov 16 2005
    Park City, UT
    I just went to snows this past weekend. I had a set from my old VW MKVI R that are a little smaller.
    18x8 Neuspeed RSe12 Light Weight Wheel @ 19 lbs wrapped in 225/40-18 Dunlop Wintersport 4D @ 21 lbs.
    I have heard you can code different revs/mile in in vcds. Does anyone have a link on how to do this?
    Tire Size Comparison
    Specification Sidewall Radius Diameter Circumference Revs/Mile Difference
    255/30-20 3.0in 13.0in 26.0in 81.8in 775 0.0%
    225/40-18 3.5in 12.5in 25.1in 78.8in 804 -3.6%
    Feb 01 2015
    2017 Subaru Outback
    United States
    Your 0 to 60 times just got a little faster. That would be interesting to type in a calibration number to keep the speedo accurate, I found some interesting reading regarding changing a multiplier in other VAG cars.
    http://forums.ross-tech.com/showthre...ibration/page2
    Not sure how it applies to our cars.
    2016 TTS
