Results 1 to 8 of 8
    Senior Member Three Rings 2wookies's Avatar
    Jun 03 2016
    Omaha NE
    Just showing off
    Had a buddy who bought a C class with 130k miles that needed some serious help.
    I'm in Omaha NE and the temperature was around 35 degrees with strong winds...soooo inside wash
    Always tape off!!
    First cut using the chemical guys Black optics orange pads, these things really do cut quickly. First time using this pad and loved it, I used Meguiars 105 for this step.
    http://vid138.photobucket.com/albums...pss55ujxih.mp4
    Next was the polish again trying out the black optics line from Chem guys...the polishing pads did not live up to the hype. Using Megs 205 I could not get them to finish clean!
    Switched it up to a traditional foam black pad, much better.
    Had to make the emblem pop a bit with intimidator metal polish
    Finished it off with a coating of Fusso sealant for winter prep(that scratch above the wheel is DEEP)
    Happy detailing.
    Feb 17 2013
    Q7 . A3 3.2 Quattro and way too many cars in the garage.
    Burlingame
    Nice and clean. 105 and 205 great combo. What did you use as your LSP
    Jun 03 2016
    Omaha NE
    The fusso sealant. Didnt want to put wax on before winter.
    Veteran Member Four Rings pdqgp's Avatar
    Mar 06 2015
    a 12 Second boat, & Wife's Lincoln
    Columbus, Ohio
    Quote Originally Posted by 2wookies View Post
    What was the paint code on the car? With newer MBZ always check to make sure it's not a C-code which is their Creramic-Clear Coat topped paint. If so, realize that this paint is different as the "cerami"clear top coat is sprayed, the nano particles of Fumed Silica (SiO2), which are synthetically engineered, migrate to the top 0.2 mils of the clear coat as it is curing. If you remove this potion of the clear layer of paint, the paint under it will be much softer and will not polish out or react the same way the nano particle portion did or would. You will at some level have compromised the the finish on the car and have trouble finishing it out. C040 is an example of MBZ Ceramic Black.
    Overall it looks good. To remove the slight haze as seen in this pic, hit it with a refining polish like CarPro Essence and a white pad. You can then top it with a silica coating or even something simple like a synthetic sealant even. Another great option for MBZ or BMW's with Ceramic Clear Coats is Wolfgang Total Swirl Remover and Finishing Glaze. From there you seal with a non-cleaning wax or paint sealant. Dozens of good ones to choose from.
    2018 Midnight Black Metallic AWD Infiniti Q50S Red Sport | Burger MS JB4 | 395awhp/430awtq
    2018 Ruby Red Metallic Lincoln MK-C Reserve | AWD 2.3l EcoBoost - Wife's
    2014 Brilliant Black S4 | S-Tronic | 187mm APR Stage 2 Dual Pulley & APR TCU Tunes | APR CPS - SOLD
    Jun 03 2016
    Omaha NE
    This is what I love about detailing, there's always something new to learn. The vehicle was an early 2000 C class and I'm not sure what the paint code was. Every job I've ever done on others cars I always tell them I am a hobbyist and not a professional, haven't had any damage done to a car yet. Hopefully I can keep that streak going.
    Jun 03 2016
    Omaha NE
    So how would one tackle a car with that different type of paint? just a simple polish without any cut? Obviously always start with the less harsh pad/product combo and work from there.
    Mar 06 2015
    Columbus, Ohio
    Go with the least aggressive method possible and use quality products. On MBZ I primarily use Menzerna.
    Jun 03 2016
    Omaha NE
    Quote Originally Posted by pdqgp View Post
    Ok I just ordered some last week so glad I got lucky there.
