    Mar 05 2012
    Omaha, Nebraska
    Heated seat issue
    Hey all,
    Curious if anyone has ran into the heated seat shutting off after turning on, no matter the setting and I'm getting an electrical fault with VCDS. Before I dig into it further was wondering if there are any common fixes besides the fuse, and the heater element in the seat.
    Passenger side seems to work fine without issue, so I'd assume that the HVAC module is hopefully fine.
    2010 Audi S4 DSG Meteor Gray; Daily; USP intake/Miltek non-res W/Black Oval tips; Dual Pulley (3.139) GIAC/DSG Tune/APR CPS 11.884 @ 115.9
    Oldies-10 Blue A4 Stock,00 Nogaro Blue 6MT, 04 Moro Blue S4 6MT, 00 A4 Avant w/tip
    Aug 03 2013
    Renton, wa
    Sounds like a possible heater element to me. Something I used to do to check back when I was in the shop was check resistance across the element and compare it to the pass side which works. Quick way to tell if there's an open in the element
    '22 X3M - Stock...for now
    '14 S4 P+ DSG 034 Stage 2+ ECU/TCU 57.7/190, AWE Touring, MercRacing, AWE S-Flo, Stoptech STR-60 - Gone but not forgotten
    '14 A4 S-Line Sport Package 6MT - Totaled
    '12 Tiguan SEL 4MO.
    '03 Mustang Cobra "Stock"
    Jun 30 2009
    Washington DC
    can someone take a pic or describe the harness and location that powers the heater element?
    My avant has the same problem that the OP described, but i for the life of me cannot find the correct wire.
    Mar 21 2015
    This is the location of the seat back connector for the heater and the cable for the seat bottom comes out in the same spot as well, cant find the pinout or connector description.
    Mar 21 2015
    This might help too
    If there is a condition, where the heating or ventilation of the driver of passenger seat cannot be switched on, this will be stored as a malfunction in the Vehicle Electrical System Control Module -J519-, in the Memory Seat/Steering Column Adjustment Control Module - J136- or in Passenger Memory Seat Control Module -J521- (depending on the vehicle type and the vehicle equipment level). Currently no information is sent to the Climatronic Control Module - J255- via the data bus system; the DTC memory must be read out in each control unit or in the Comfort System Central Control Module - J393- using the Vehicle Diagnosis, Testing and Information System VAS 5051 under "Guided Fault Finding". If there is a complaint about seat heating or seat ventilation, first check the control module DTC, which controls the seat heating and seat ventilation.
    The seat heating and ventilation is adjusted by the Climatronic control module; the adjustment is transmitted to the vehicle electrical system control module via the data bus. The specified temperatures for the different seat heating and seat ventilation settings are stored in the vehicle electrical system control module. Depending on the version of the vehicle electrical system control module and on the vehicle build date, the specified temperature for the seat heating and ventilation can be different with the same setting on the Climatronic control module. Check using Vehicle Diagnosis, Testing and Information System VAS 5051 under "Guided Fault Finding" (for the vehicle electrical system control module).
