Results 1 to 12 of 12
    Veteran Member Three Rings scott99c2's Avatar
    Oct 11 2014
    Nashville, TN
    RS7 bumper conversion
    I've been searching around and I can't figure out if you need to change the headlights on a 2013 with LED's to put on a RS7 bumper.
    My S7 will need to have the front bumper resprayed due to some prior owner's indiscretions, so I'm looking at my options.
    Mar 29 2014
    Hampshire, UK
    There is no difference in the shape of the lighting units between the C7 models. (A/S/RS7s)
    The facelift C7.5 model has a different shape lighting unit, and is not backward compatible with the non-facelift earlier C7, unless you also change out the front bumper for the facelift version.
    Be aware that if you had ACC fitted and you swap bumpers, you will need to have the ACC recalibrate by the dealer.
    2016 S7 Sepang Blue ///Matrix//Bose//Self Park//Lane Assist//ACC//F&R parking cams//Blackvue DR750//Phone Box//Sunroof//Privacy glass//Carbon mirrors//Neidfaktor Steering wheel//RS Knob//OEM RS Grill//Suntek PPF//De-chromed//Modded Exhaust//Cete ASC v2 installed//APR Stage 3 w/RS7 Turbos and intake pipes + TSU//Eventuri CF intake//Carbon Diffuser
    Gone: 2014 Audi A7Q 3.0 TFSI
    Gone: 2011 Audi A6Q 2.8 TFSI
    Oct 11 2014
    Nashville, TN
    I have ACC, and I wish I didn't, but that's another story.
    Thanks for the reply!
    Veteran Member Four Rings madyspop's Avatar
    Nov 19 2005
    07 S8, 07 V10 Treg, 11 Stasis S4, 13 S6
    Central IL
    You don't have to recalibrate your ACC if you know what you're doing. My tech has had my bumper off twice now and neither time needed a recalibration.
    13 S6 Glacier Stage 3 llllllll APR DP's l Akrapovic l EC sways, endlinks and Alu Kruez l 034 mounts l Garrett GTX2873 turbos l Custom ECU/TCU tune l 3m tint l CETE Bluetooth Lowering Module l Escort 9500ci built in radar/laser diffuser l AWE Gen 2 intake l Xpel l P3 Gauge l RS 6 Grill l E-codes l APR HE l Carbon Designs valance & mirror caps l Dynamic tails l facelift rear bumper l 20" BBS CX-R on Blizzaks l 20" HRE P101 on Mich PSS l 034 density mounts
    Veteran Member Four Rings Dasquade's Avatar
    Sep 07 2010
    Belgium
    Quote Originally Posted by madyspop View Post
    Mind sharing bit more of the 'know what you doing'? ;)
    S6 C7 avant '13 estoril | ceramics | DS1 OTS stage 2 | Lightvan | Milltek non-res X pipe | TS1 | 034 trans-diff mount | CETE ASC-EVC | FL tails & dynamic signals | Thermo ZO catless DP | SRM a2a | BC Forged 20" HCA162S | custom spoiler sideskirts | Maxton front lip & diffuser | Armor heatshield mani-turbo-dp | B&O led tweets (repli) | Forge boost hoses | FIS mmi gauges | R8GT steeringwheel | alcantara interior | SRM inlets | R8 exclusive seats | JXD driveshaft | Tial WG
    Senior Member Two Rings Thisisnoise's Avatar
    Oct 16 2012
    Los Angeles CA
    Just did this bumper swap due to a minor fender bender and was very simple to do - simple plug and play although I don't have acc.
    2014 S7 Black Pearl- Black Optic- HRE FF01 -Michelin SS - APR Downpipes- RS7 turbos - APR stage 3 Ecu/Tcu-Alpha cooler- AWE Track Exhaust -RS7 Grille and Bumper - TAG Blackout Emblems - TAG Painted Reflectors - Euro Facelift Taillights - ABT CF Spoiler - Eurocode Sways /Links - Eurocode inserts - XPEL Stealth- Opticoat- Optiguard - VIP Stinger radar and laser - Alu Kruz - Carbon Fiber FB steering wheel- CF front diffuser -CF mirror covers
    Mar 29 2014
    Hampshire, UK
    Taking an ACC bumper off and putting the same bumper back on does not require a recalibration, unless you have removed the radar modules and refitted them, or replaced one etc.
    Fitting a band new bumper, and transferring the ACC radar modules to the replacement bumper requires a recalibration, this is what the OP is discussing.
    Saint Cloud, Fl
    I changed to an RS7 bumper and I did not recalibrate. The system still works flawlessly.
    instagram ------------> low_enforcement
    Oct 11 2014
    Nashville, TN
    Quote Originally Posted by 7speed View Post
    Looks great! Did you use OEM or aftermarket?
    Scott
    2013 S7 | Prestige | Estoril Blue | Lunar Silver | SRM RS7 +4mm Turbos | SRM Short Intakes with RS7 Airbox | DS1 Stage 4 ECU | APR TCU | AMS Catted DPs | AMS Cooling Package | OCarbon Large Weave Carbon Package | Alu Kruez | Eurocode Sways | HRE FF01 20 X 10.5"
    2021 SQ7 | Prestige | Black Orca Metallic | Black Optic | Luxury Package | Laser Lights | Tow Pkg |
    Mar 29 2014
    Hampshire, UK
    In that case I stand corrected.
    Ive had my C7.5 bumper on and off to do a grill upgrade, and discussed this with my dealers tech beforehand. I only repeated what he told me about ACC. He said that as a safety critical system, if you move the sensors on the bumper, or transfer them to a new bumper, then the system has to be recalibrate. Maybe he meant may need to be recalibrate if the system shows errors after reassembly...
    To the OP, good luck, and let us know how on get on with your ACC
    Saint Cloud, Fl
    Yes, I'm no expert, but I swapped bumpers and have had no problems. However, I did read that you can not power up the car with the sensors removed, so I left the car powered off until I had competed the swap.
    I used an aftermarket bumper and side skirts.
    Oct 11 2014
    Nashville, TN
    What brand? How was the figment?
