So yesterday evening I'm cruising down the freeway and the engine just stalls. Wtf?! I pull over and look around in the engine and then I see it. The moment I pulled the timing belt cover I see a good number of teeth are missing from the belt. AAA got the car home and the tear down will began. I sadly couldn't find my head bolt tool so the rest will have to wait until I can go find another head bolt tool. I do have my 2003 A4 parts car from which I can go harvest an AMB head. Then install the new head, gaskets, and a new timing belt followed closely by crossing some finger for the compression test.
Last night I did pull the plugs and send a borescope in to see the damage. It looks similar, maybe not as bad as pictured in the VW Vortex thread.
http://forums.vwvortex.com/showthrea...ed-piston-tops
Questions:
1 - Does anyone know of any reason why the AMB wont work in place of an AWM head?
2 - If/when the valves hit the piston, if the valves scratched or very slightly marred the piston head from the impact would I have to replace the piston head?
3 - Any advise or is there anything I am not thinking of?
