    Veteran Member Three Rings achb5's Avatar
    Feb 06 2009
    2001.5 S4 QM
    santa fe NM
    ABS/ESP Pump bleed
    It seems the Ross Tech wiki no longer has this procedure. If I understand correctly one pressurizes the system (power bleeder), cracks the bleeder, runs the ABS/ESP pump via vag com, waits for pump to shut off, closes bleeder, moves to the next wheel. Is that correct? Can anyone who has done this recently share the procedure. TIA
    Mine is the 01' w/ESP
    Aug 06 2008
    Canadia
    Theres a million answers, even the independant shops cant figure it out... A local guy is a service advisor at a reputable dealer, and im just going to get his dealer to do it for $150
    the B5 S4 is like the mafia... there is only one way out!
    Feb 06 2009
    2001.5 S4 QM
    santa fe NM
    Quote Originally Posted by MacDaddy View Post
    Theres a million answers.......
    Thats been my experience as well.
    Veteran Member Four Rings Timtheguru's Avatar
    Dec 30 2009
    Quote Originally Posted by achb5 View Post
    No, you only bleed at the driver front wheel for the ABS pump, per the Bentley. Don't necisarily need a power bleeder, but a nice to have.
    The driver front wheel should be the last wheel you bleed anyway, so right after I manually bleed the brakes in all 4 corners I do the ABS pump and one last manual bleed on that wheel. Pass Rear > Driver Rear > Pass Front > Driver Front > Bleed ABS with VagCom at Driver Front > Manual bleed Driver Front
    2001.5 S4 Sedan
    2002 A4 Avant 1.8t - Traded in
    2001.5 A4 1.8t - Sold for $5
    2013 Q7 TDI Premium Plus (RIP, rear ended and totaled, assholes)
    2013 Q7 TDI Prestige S-Line
    2018 Q5 2.0t
    2022 e-Tron Chronos Edition
    Feb 06 2009
    2001.5 S4 QM
    santa fe NM
    Thank you! That clears things up for me.
