Results 1 to 18 of 18
    Junior Member One Ring MixedNutz's Avatar
    Aug 08 2015
    Simple wheel spacer question for a new guy.
    I have a 2011 A5 2.0
    I was wondering what size spacers would you recommend to just space the rear wheel equal to the front wheels or slightly more.
    Also, will this have any other affect on the car?
    Oct 02 2016
    solihull uk
    You really need to measure the distance as all depends on wheel width size/offset etc. Usually the rear spacers need to be about 5mm wider to even out the look. Eg 20mm spacers for rear and 15mm for front. I would recommend measuring using a straight edge from the ground up against both edges of tyre and measuring gap between it and wheel arch lip to give you an exact size and then you can use that size for an aggressive look or just slightly less depending on personal choice.
    Hope this helps.
    Sent from my D5803 using Audizine mobile app
    Aug 08 2015
    ok thanks, I only have the factory wheels on.
    Sep 28 2010
    NW NC / DE
    3mm at the rear will have you dead on, 5mm will actually provide a bit of poke. Hit my Flickr if you like, and look at my old A5. I ran many sets of wheels, and ran 3 or 5mm more at the rear with each set.
    5mm...
    IMG_2689 by Audiyos, on Flickr
    IMG_2595 by Audiyos, on Flickr
    You also must consider drop/camber.
    Aug 08 2015
    Ok I will def check the pics out
    Senior Member Two Rings PDXFlyGuy's Avatar
    Nov 24 2016
    2016 Cadillac CT6
    Portland, Oregon
    5mm...
    Hot car! Newbie here! I just bought a 2014 S5 with the 19" rotor wheels. I don't intend to lower my car but I am curious about spacers. I've read that some people do 15mm in front and 20mm in back. You mention 3mm and 5mm. If I just want to bring the wheels out even with the fenders what would you suggest?
    2018 Glacier S5 SB
    Sep 28 2010
    NW NC / DE
    Quote Originally Posted by PDXFlyGuy View Post
    Not lowered, 10/15 would be my selection And thanks!
    Senior Member Two Rings Feryunda's Avatar
    May 29 2007
    2013 Audi A5
    Charlotte, NC
    I'm not sure of the offset in the OEM 19" wheels and probably Mops is correct with 10mm (f) and 15mm (r), Everything depends of the wheel offset and if the car is lowered or not. When I just got my A5 with OEM 18"x8.5-29 offset wheels and OEM suspension I got 15mm (f) 20mm (r) for a perfect flush and then I lowered so I switch to 20mm(f) and 25mm(r), this because the camber when it is lowered. Now with the HREs 20 x 10.5-35 offset I have 5mm (f) and 7mm (r). I wish I can have 10mm at the back, but none of the hubcentric 10mm spacers out in the market work with my wheels/car hub combination ...:-(
    Nov 24 2016
    2016 Cadillac CT6
    Portland, Oregon
    2018 Glacier S5 SB
    Veteran Member Four Rings JamesRS5's Avatar
    Feb 27 2014
    Dubai
    Here's a great guide from ECS on how to measure for spacers:
    https://m.youtube.com/watch?v=3LeFZsyGRrs
    Nov 24 2016
    2016 Cadillac CT6
    Portland, Oregon
    Quote Originally Posted by JamesRS5 View Post
    Thanks James!!
    2018 Glacier S5 SB
    Apr 02 2016
    none
    i have 15MM H&R in the rear but my front 10mm H&R spacers would not fit my aftermarket wheels because of the beveled edge on the spacer
    so now im stuck i done want any vibrations thats why i chose these
    https://goo.gl/photos/Ba1jPdYiUvrtr3jd6
    2014 s5 DSG-Prestige-Ibis White-Alcantara Seats with Carbon Fiber Trim-B&O-Sport Diff
    Senior Member Two Rings T_Glass_27's Avatar
    Jan 21 2013
    1988 Porsche 944S
    Mooresville, NC
    I bought a kit from ECS for all 4 spacers and lugs. I bought new wheels and dont need them anymore if anyone is interested. 50 bucks shipped
    Active Member Two Rings Stone05's Avatar
    Nov 06 2014
    Northern Va
    What size are your spacers?? ^^
    Junior Member Two Rings
    Jan 23 2015
    Long Beach, CA
    I just got aftermarket wheels too and they look "sunken in" to the fenders. Looks like I have the same question.
    I'm going from the stock wheels (I believe they are 18x8.5, 29 offset) and I got some Monte Titano 18x8 with 35mm offset.
    The front is not bad but it's noticeable in the back.
    Veteran Member Four Rings Sweep's Avatar
    Sep 05 2014
    Quote Originally Posted by FlyBono24 View Post
    Higher offset pushes the wheels in, narrower wheels will also push the wheels in. You got a higher offset AND narrower wheel so that's doubly bad
    Sent from my SCH-I545 using Tapatalk
    Ken
    2021 Q5e Prestige
    District Green
    2013 A5 Premium+ 6MT
    Glacier White | E-Codes | Bilstein | STaSIS | Roc-Euro | VMR V810 | Hankook | SunTek CXP
    Jan 23 2015
    Long Beach, CA
    Quote Originally Posted by Sweep View Post
    Yeah I got these ones from TireRack http://www.tirerack.com/wheels/Wheel...dClar=Prestige
    They look great, they just need some spacers.
    I'll have to measure them later but I'm thinking 15 or 20mm in the rear? Would that affect performance at all? Would they be less safe with a larger spacer like 25?
    Sep 05 2014
    No, I'm running a 25mm rear spacer right now for my winter setup
    Ken
    2021 Q5e Prestige
    District Green
