Results 1 to 20 of 20
    Established Member Two Rings xwilliams23's Avatar
    Aug 05 2015
    2006 Mazda 6
    Milton
    HELP! What is this noise? (VIDEOS)
    Any idea what this noise is? Gets pretty bad at 100kmh. But goes almost all the way away at like 140. Audible at low speed. But not audible at really low speeds.
    Speed dependant. Gets faster and louder. Goes away with right turns. (That's the passenger rear)
    NO wheel bearing play with hands on 12 and 6 with wheels off the ground.
    THANKS
    Established Member Two Rings bwizard's Avatar
    Oct 10 2016
    Colorado Springs, Colorado
    Sounds like a bent backing plate rubbing against your rotor or a warped rotor
    Sent from my S4's talk to text @ a buck thirty
    weekly driver 02 S4 2.7t auto stock
    Wife's 04 A4 1.8t auto stock
    Daughter's 97 A4 AEB Bored to 2.0t K04 sport cams
    My role family tech.
    Oct 10 2016
    Quote Originally Posted by bwizard View Post
    Sounds like a bent backing plate rubbing against your rotor or a warped rotor when your spinning by hand
    Aug 05 2015
    2006 Mazda 6
    Milton
    Even when driving itd make that noise like in the second clip? Ill have my wheel off in a bit and check
    Sep 07 2012
    Tucson, AZ
    Check the backing plate and bend it back if needed and/or possibly a loose caliper or missing caliper bolt.
    Aug 05 2015
    2006 Mazda 6
    Milton
    Quote Originally Posted by LightningLou View Post
    Alright ill see if thats the issue
    Jul 07 2009
    Alberta, Canada
    When (how long ago) did it start happening? Getting worse?
    Happened out of nowhere?
    Aug 05 2015
    2006 Mazda 6
    Milton
    Quote Originally Posted by JVD View Post
    Yea. Happened after A pull. gradually got worse but it's staying in the same state hasn't gotten worse since it got this bad
    Sent from my SM-G925W8 using Tapatalk
    May 16 2008
    WA
    the fact that it goes away around turns leads me to think it may be the wheel bearing. Granted I have never heard one that sounded quite like that on a B5, but have heard similar on other platforms:
    There doesn't necessarily have to be excessive play in the wheel for them to be considered bad.
    Aug 05 2015
    2006 Mazda 6
    Milton
    Quote Originally Posted by getslideways View Post
    Not that there isn't excessive play in the wheel there is literally no play whatsoever. But yes On tight right or long banking right turns. Its un audible or very quiete. Aswell, ive been Researching alot of wheel bearing noises and havnt heard this type of noise..
    Possible CV Shaft?
    May 16 2008
    WA
    It's definitely possible to have a completely failed wheel bearing and yet still pass the "shake a wheel" test.
    Did you watch the second half of that above video? It sounds very similar to the second video you shared in your first post. That "Driving over a grated bridge" noise.
    All the other symptoms you described point to the wheel bearing in my opinion (getting quieter when loaded/turning, consistent with speed not rpm, etc). Could it be something else? CERTAINLY, however if I were a betting man, that is where I would place my money (especially since rear wheel bearing failure on the B5 platform is not uncommon), and since wheel bearings are not expensive or terribly difficult to install, that is where I would start. Either way I hope you find the source and report back to what ends up fixing it
    Aug 05 2015
    2006 Mazda 6
    Milton
    Thanks. Im gunna take your word for it. Ordering a pair of wheel bearings for both sides.
    Senior Member Two Rings jrow26's Avatar
    Apr 01 2016
    2007 Jeep Wrangler 4door
    GA
    I know I had a similar sound and it was one of the bolts holding the I think wheel bearing or rotor on... it had backed out and was rubbing against the drive shaft ..
    Aug 05 2015
    2006 Mazda 6
    Milton
    Quote Originally Posted by jrow26 View Post
    Taking wheel off after work. Ill have a look for this. Thanks!
    Jul 04 2012
    Woodbridge, VA
    That is absolutely wheel bearing(s).
    Wheel bearing play usually shows up in the non-pressed in bearings or one thats are so far gone they are litterally falling apart. There arent very many other things it could be. CV or rotor wear/rust lip. But this would be pretty obvious. I feel its too constant to be CV so that leaves one thing: wheel bearing. Listen to getslideways, he knows his shit.
    May 16 2008
    WA
    Quote Originally Posted by vavJETTAw36 View Post
    Jul 04 2012
    Woodbridge, VA
    Sweet. Ms paint?
    Sep 09 2014
    Grand Rapids, Michigan
    100% a wheel bearing. Had one that failed just like this
    Quote Originally Posted by Trb1 View Post
    Also my suggestion. Bearings do not have to have a horizontal moving when they r bad... so there is no play when you move the wheel
    Veteran Member Three Rings rguil's Avatar
    Dec 17 2014
    San Diego CA
    Dude its gotta be a wheel bearing, that's how my b5 sounded with a bad wheel bearing when i first bought it. Drove me nuts!
