Results 1 to 4 of 4
    Sep 29 2016
    Manhattan, ks USA
    5.2 v10 need some help
    Alright I have a couple questions I am hoping you guys can help me out with. I replaced my oil pan gasket a while back because it looked as though it was leaking. I noticed the other day that I was leaving oil spots on my drive way so I took the car to work and picked it up. It looks like the oil pan is leaking again. I did the oil pan again and the oil spots didn't go away. I started to do some more research and I believe my oil filter housing gasket is leaking and oil is running down the front of my engine. I ordered new gaskets for the housing and intake and I plan to attack that in the upcoming weeks. This leads me to my big question. Lately when I come to a stop at a light I smell burning oil, I even get a little bit of smoke. I cant tell if me running the heater has anything to do with it or not. I have inspected my valve covers and they don't seem to be leaking, maybe a small seep but nothing alarming. I can see where oil has been running out the drain holes on the front of the engine(will upload picture shortly). Have any of you guys had this issue?
    Sep 29 2016
    Manhattan, ks USA
    Sep 29 2016
    Manhattan, ks USA
    sorry these are the best pictures I could get without removing the front of the car. you can see it has been running out pretty good. it has cleaned a path pretty well
    Active Member Four Rings kingofnyc's Avatar
    Jul 02 2007
    Queens, NY
    Had same issue in my S6. It was a oil filter housing gasket.
