Results 1 to 11 of 11
Thread: ODBEleven Help
    May 31 2011
    moore
    ODBEleven Help
    I can't seem to get started on any of the code. I tried to disable drl wink, enable opening of windows with fob, etc... But wa greeted with a module unavailable or something to that affect. The code I'm using is from the VCDs list, please advise.
    Senior Member Two Rings grrrrrrr's Avatar
    Mar 27 2008
    valencia, california
    Everything should be just on and off option correct? Never had issues with obdeleven. I used mine for enabling VIM.
    Sent from my SM-N920I using Tapatalk
    May 31 2011
    moore
    Are you using the same code as those for the vag-com to enable VIM? Mind giving me detailed info since I can't seem to do anything. The software is recognizing my car as an A4 if it makes any difference. But when I go into the Info screen it shows the correct engine (3.0 instead of 2.0).
    Senior Member Three Rings JimmyS3's Avatar
    Aug 13 2016
    Pennsylvania
    If ur getting the module unavailable it means u are connected to the Obdeleven. Is this with the car running or theven the car just "on" not running?
    :: 2018 S4 ::
    - 034motorsport - APR - CTS - EMD - ECS - MBRP
    May 31 2011
    moore
    Car was running (hold down brake pedal + Start/Stop button).
    Sent from my Nexus 6 using Audizine mobile app
    Mar 27 2008
    I just followed youtube guide.
    https://youtu.be/SbxiRHPw2sQ
    Aug 13 2016
    Pennsylvania
    Most of the coding I did was not with the car running on in the on position.
    Is it asking for the security code or anything?
    :: 2018 S4 ::
    Veteran Member Four Rings blackfunk's Avatar
    Jul 12 2012
    Just curious, why this over Carista? I'm asking because Carista is fairly active on these boards and they're pretty responsive with questions.
    Life has taught me never try to make something idiot proof, they'll simply come up with a better idiot.
    I'd agree with you but then we'd both be wrong.
    I have neither the time, nor the crayons to explain this to you properly.
    Mar 27 2008
    I bought the obdeleven just solely for the VIM. I also have carista.
    May 31 2011
    moore
    This is just $60 and no recurring monthly/yearly fee.
    Jul 12 2012
    Ok, I forgot about the price increase for Carista. I was an early tester and got a different price.
    Sent from my SD4930UR using Tapatalk
