Results 1 to 9 of 9
    Senior Member Two Rings djshaunmichael's Avatar
    Mar 13 2013
    Boston
    How to Eliminate Thule Noise
    I am getting a loud whistle noise from my aero bars when driving... anyway to eliminate that?
    2018 SQ5 Ibis White, Black Diamond Int, S Sport
    2014 SQ5, Estoril Blue
    2010 S4 Prestige ,Black/Black, Sport Dif, RS4 Front Grille, 30% Optic Tint
    Veteran Member Four Rings riceboy22's Avatar
    Mar 26 2015
    2015 Audi SQ5, Felt F65x, Levy Electric Scooter
    New York, NY
    Quote Originally Posted by djshaunmichael View Post
    Do you have them facing in the right direction? Not trying to be a smart ass, but the first time I looked at them I assumed the wider side should be towards the rear when it's actually the opposite. I don't get any whistling noise from them, so I'm assuming something must be off with yours.
    Current
    2015 Audi SQ5 3.0 TFSI (Build Thread | Flickr | Instagram)
    Past
    2006 Lexus IS350 | 2001 Audi S4 | 2000 Honda S2000 | 1999 Yamaha YZF-R6 | 1995 Acura Integra GS-R
    Oct 06 2016
    CA
    Quote Originally Posted by riceboy22 View Post
    Picture reference to what @riceboy22 said:
    Veteran Member Four Rings MacFady's Avatar
    Aug 10 2011
    330i ZHP
    Prince Edward Island
    Like any airfoil.
    Junior Member Two Rings dassq5's Avatar
    Sep 18 2015
    2019 Audi A4 Allroad
    colorado
    It also depends on which rubber inserts you have. The older Thule bars have a smooth rubber strip which lends itself to whistling noises. The newer bars have raised diagonals on the rubber strips which breaks up the airflow that causes the whistling.
    Senior Member Two Rings AUDuffer's Avatar
    May 20 2012
    Hawaii
    Quote Originally Posted by dassq5 View Post
    Which can be purchased for cheap.
    Oct 01 2016
    2014 Q5 TDI, Orbea Oiz Carbon XTR
    Boulder CO USA
    Are the Thule Aero bars much different than the Audi bars that came with the Q5? Looks like the Thule are more aero in shape vs the Audi ones. Just wondering if anyone has had both and experienced much of a differnce between the two in regard to wind noise? I have the Audi ones but was wondering if it was much of a noticeable difference to upgrade to the Thule Aeros.
    I use it with bike racks ( Thule Thru ride 535) so I don't know if it will really make much of a difference anyway.
    Senior Member Three Rings Tinpusher's Avatar
    Sep 27 2009
    Caledon, ON. Canada
    Leaving bars on when not actually carrying anything (an empty bike rack does not count as something) seems to be fashionable. If you are carrying something be it a bike or whatever, its going to be noisy so worrying about the noise your bars might make is a bit pointless. If you're not using them, take them off, then you wont have any extra noise.
    Mar 26 2015
    New York, NY
    The Thule AeroBlades are definitely quieter for me than the OEM bars. I hear almost nothing with the AeroBlades by themselves. It may not make as much of a difference though as you pointed out when you have bike racks up there. Those are going to make more noise than either set of bars.
    @Tinpusher, I hear you about taking them off when not in use, but that's not always practical or convenient to do on a regular basis. I don't use them on the weekdays, but I'm not going to take them on-and-off every weekend.
    Current
    Past
