Results 1 to 40 of 68
    Nov 18 2016
    Slow C7 S6 owner
    Hello all,
    Im coming from M5s and AMGs and supercharged Range Rovers and now I picked up a 2013 S6 with 37k miles for work duties. I bought the car which had an USP intake and found out it also had an APR tune on it (dealer didn't know). I had it updated and transferred to my name and Im on the 93 tune.
    I cant seem to get launch control to work - I think the previous owner maxed it out at 200. Thats another story, but if I brake torque a bit and take off without LC, it doesn't seem to have that extra grunt I would expect, especially in the 60-100mph range. I'm taking the car to the dealer or some other issues (P2273 code, P0141, P0161, P0140, P0160) and Im secretly hoping that they are affecting the performance so it will remedy itself once this is fixed. I know they are o2 sensor codes, which I clear with my handheld unit but come right back.
    Is there anything else I can check? Should I post a video and report back?
    Thanks
    Sep 04 2011
    Central NJ
    Quote Originally Posted by AWOL View Post
    Hello all,
    Thanks
    You could add the APR TCU tune to raise your launch limiter to 3000. Last night on my APR 93 EDU/TCU tune I did the break torque. I had some wheel spin but 0-60 times using VBOX sport were 3.5s twice. The third time I had so much wheel spin that I let off the gas a bit and that run was 3.8s. So I can't really complain that the APR 93 tune is slow. Hopefully getting your other issues fixed brings back the speed to your car. BTW, are you taking the car back to the dealer with the tune on? If so, there is a chance that you may have to pay for your issues yourself as Audi may give you a TD1.
    2016 Audi S6 Prestige
    2015 Audi Q7 S line Prestige
    Mar 30 2015
    Denver
    You can check the number of launches using VAG if you have access to one - to confirm that it's at 200. If it bother's you, the APR TCU tune, as well as others, can increase the launch limit.
    With all those codes, it is likely you are running into at least some moderate limp mode. Once fixed/cleared, I'm guessing you'll have improved acceleration.
    2013 S6 - Estoril Blue - Lunar Silver
    Feb 25 2014
    Texas
    As stated above, the TCU tune will remedy the max launch issues.
    Mickey (AKA: AudiS4B8)
    Instagram: ze_nardo6
    10.65 @ 129mph
    Veteran Member Four Rings MileMan402's Avatar
    Mar 14 2012
    PHL | BOS | SEA
    Sorry but your description of "slow" is extremely vague and undeniably subjective. We need logs to give you a definitive answer as to whether your car is actually slower than it should be or slower than you were expecting.
    2014 S6 - SOLD
    2016 Focus RS - SOLD
    2012 Wrangler Unlimited
    Nov 18 2016
    Yes, Ive looked at the TCU tune when I had the APR warranty transfer done, but that seems pricey. Id rather fix my other issue(s) first before diving into that. I do understand that it raises the launch count as well. I follow the directions Ive seen online, ESP is off, but not this "ASR" or whatever it is. I hold the button and nothing changes.
    Also, I clear the codes, but they show up as pending right away and then the light comes on after a few more minutes. I really hope this is the issue. Im seeing like 4.1-4.2 0-60 without LC in this 93 tune, and my daily mpg is terrible. I expected better results, both in power and efficiency. I hope I dont have a dud
    Senior Member Two Rings schaNYC's Avatar
    Jun 06 2016
    Quote Originally Posted by cohall View Post
    where do u go in VCDS to check this? Thx
    2013 S7 | Ibis White/Black | EPL stg1 (sold)
    2011 Q5 3.2 FSI P+ | Deep Sea Blue/Black | S line (sold)
    Mar 30 2015
    Denver
    Quote Originally Posted by schaNYC View Post
    http://www.audiworld.com/forums/s6-c...unter-2843486/
    Veteran Member Four Rings saxon's Avatar
    Oct 16 2012
    pa
    hey man welcome to the forums
    are you sure you dont have downpipes on the car? i know you didnt know about the tune at first so it could possibly have downpipes as well, or maybe it had them and when converting back to stock they did something weird to them.
    Current Ride- 2018 Audi RS3 Glacier White
    Unitronic- 10.0@136mph race prepped
    10.5@133mph winter tires full street prep
    Past cars 2010 s4-2012 Nissan GT-R -2014 S6-2016 s3-2015 M3--2011 b8 s4
    Nov 18 2016
    Maybe it did and they put it back to stock. They at least look original to me. I'm putting the car back on the stock tune prior to me dropping off the car at the dealership for service so it doesnt get flagged.
    Heres a video: https://youtu.be/0i-GkX0qMbk
    I have more, but I made sure to edit the video to start me moving at 3 seconds. Most of my launches come in at 4.1-4.2 without launch control. I wanted to see sub 4 without it and 3.5 with it.
    Feb 25 2014
    Texas
    Yea...that is definitely not a slow car LOL
    10.65 @ 129mph
    Sep 04 2011
    Central NJ
    Maybe I misunderstood your wording but putting the car on the stock tune of the APR ECU will not prevent getting flagged. You need to flash the ECU back to stock. After getting your issues fixed report back on 0-60 times. On the APR 93 file I get 3.8-4.0s just flooring the gas pedal and ~3.5s with break boost and some wheel spin. I have not yet done a proper launch.
    Nov 18 2016
    Quote Originally Posted by hmuller View Post
    Damn. Good to know.
    Feb 14 2014
    13 S6, 13 Q5, 72 Chevelle
    Oklahoma City
    These cars are not highway monsters, 60-100 does not feel near as good as 0-60.
    13' S6 - Phantom Black - Unitronic ECU and DSG - Roc Euro - Links and Spacers
    Oct 16 2012
    pa
    Quote Originally Posted by MikeDwerks View Post
    Trapping 120mph isn't exactly a slow highway car
    Established Member Two Rings Roadwarrior's Avatar
    Oct 01 2016
    Atlanta, GA
    neither do handcuffs with blue accent lights. Seriously, speed is relative. To me, it is plenty fast. I have owned more brutal cars but this car rides the rail. It is like a swiss army knife (It is brilliant with many duties) and I don't have unrealistic expectations. Therefore, I love my S6.
    2015 Audi S6- Phantom Black Pearl Effect, Black Interior, Black Alcantara Headliner, Driver Assistance, Night Vision Assistant, Carbon Atlas Inlays, Cold Weather Package, 20" OEM Wheels. Mods- AWE Touring Exhaust, Bel STI R+, ALP Laser Shifter, RS6 Intake. On the way but not installed: Alu Kruez, Sways, End Links and Mounts.
    Nov 18 2016
    Took my cover off today. Is this right?
    Are these wastegates suppossed to be in the same position? one looks open, the other looks closed.
    Oct 16 2012
    pa
    Is that with the car running or off
    Nov 18 2016
    That was with it off. I was thinking along the same lines and when I turned it on, nothing changed.
    Feb 14 2014
    Oklahoma City
    Quote Originally Posted by saxon View Post
    No, you are certainly right
    Was just responding to the OP's original comment about being used to M5's and AMG's. The s6 does not pull as hard at higher speeds comparatively to some of those cars, it just doesn't. Does not mean it's slow.
    I personally enjoy that is is more fun in gears 1,2,and 3 as going 140 mph+ on public roads just ain't smart nor my cup of tea
    Feb 14 2014
    Oklahoma City
    Quote Originally Posted by Roadwarrior View Post
    I love mine too for those same reasons
    Not sure what your getting, I just said it's not a highway monster... and it's not.
    Veteran Member Four Rings gk1's Avatar
    Aug 06 2014
    NJ->CO
    See if you can watch them shortly after shutting car off, I believe they normally cycle.
    2023 e-tron GT Daytona Gray
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    2014 SQ5 Glacier White
    2012 S4 S-Tronic Monsoon, Stage II [email protected] 4275lbs
    2008 A6 3.2Q S-Line Daytona
    2007 A4 2.0T S-Line Ice Silver
    2001 S4 Nogaro Blue, Stage I [email protected] 3944lbs
    Feb 09 2016
    Houston
    Exactly man. I don't get this new crowd with the highway roll racing. I know everything has 500+ hp now but this game has changed so much.
    2014 A8L 4.0T - RS7 Turbos, DS1 Stage 3 Tune, Full E85, Stock Downpipes, Stock LPFP. [email protected] mph
    Mar 26 2010
    US
    Quote Originally Posted by Chris Morales View Post
    It helps for RWD cars.
    2019 RS5 Sportback
    Established Member Three Rings fatherdeath's Avatar
    Jul 20 2016
    2016 Honda CRV EXL, 2006 Dodge 2500 laramie mega cab, 1974 Buick apollo
    Tampa, FL
    ive been able to very easl get mine to 140/150 so far not many have been able to beat the S6 unless they are the higher level VW groups cars with a GTS on them
    SOLD:2017 S6 Mythos Black Arras Red interior all the Wayne tech gadgets, RocEuro, EPL stage 1, 15mm front/20mm rear spacers, Eurocode Sways, end links, billet mounts ALL
    American enjoying the autobahn
    Nov 18 2016
    The wastegate on the left side of the photo actuates when the car is on and I rev the engine. The driver side wastegate does not move at all and is very very hard to move manually. I dont think this is right.
    Secondly, when I stay in it after 85-90, the EPC light comes on and it sounds like it dumps all boost. I reset the code, and it does this every time at 85-90 WOT.
    I did manage a better 60mph pull, but here are some times. Going to the dealer on Monday for the o2 stuff.
    Is under 7 seconds to 90 on par without using LC?
    Nov 18 2016
    Looking at the waste gate actuators, the driver side one is a different style. I thought this was normal, but looking at all the photos I could online, both sides either have a bent rod type actuator or a straight rod. Mine has one straight and one bent. My driver side is the bent style and I don't think this is right. It's like the arm is too short and pulls the actuator in and holds it.
    F
    Veteran Member Four Rings Dasquade's Avatar
    Sep 07 2010
    Belgium
    For what it is worth....mine (both closed).
    (clearly? a malfunctioning wastegate...should be closed)
    S6 C7 avant '13 estoril | ceramics | DS1 OTS stage 2 | Lightvan | Milltek non-res X pipe | TS1 | 034 trans-diff mount | CETE ASC-EVC | FL tails & dynamic signals | Thermo ZO catless DP | SRM a2a | BC Forged 20" HCA162S | custom spoiler sideskirts | Maxton front lip & diffuser | Armor heatshield mani-turbo-dp | B&O led tweets (repli) | Forge boost hoses | FIS mmi gauges | R8GT steeringwheel | alcantara interior | SRM inlets | R8 exclusive seats | JXD driveshaft | Tial WG
    Nov 18 2016
    Quote Originally Posted by Dasquade View Post
    Thank you. I will inquire with the dealer tomorrow.
    I'm thinking I got bought a hack job and have some work cut out for me.
    Veteran Member Four Rings Sanjman's Avatar
    Nov 16 2006
    nothing else special
    Skokie, IL
    For all you can hope for you have RS TURBO$ :)
    Oct 16 2012
    pa
    I would highly suggest going back to 100% stock at the APR dealer before going to audi
    Nov 18 2016
    Just called the dealer prior to appointment and this god damn car is already flagged as TD1.
    So whats left being covered under warranty? Do I lose all power train and transmission coverage?
    This whole car thing has been a huge piece of shit
    Feb 25 2014
    Texas
    Did you not research the car before purchasing?
    10.65 @ 129mph
    Jul 20 2016
    Tampa, FL
    Nothing your car has 0 warranty for all items unless you hire a lawyer to fight for it
    Nov 18 2016
    Quote Originally Posted by AudiS4B8 View Post
    I did what I could. I bought this out of state. I had the carfax done, talked to my local dealer confirming warranty in place until 7/12/2017 based on the VIN. Has Audi Care until 50k miles. Always serviced regularly, just done at 35k. I went down and looked it over, test drove it, etc. I popped the hood but kept the cover on. Even if I did pop the cover off, I wouldn't have caught the o2 sensors or known about this wastegate issue. It only had 37k miles, and was a southern car, and the interior is flawless. Everything appeared to check out, and i felt I was pretty thorough.
    I didnt know it was tuned until after I purchased it and was waiting for delivery. I thought that was a nice bonus, but now at the expense of my remaining warranty and hopefully aftermarket warranty, it's not worth it. Especially with all of these issues popping up.
    Nov 16 2006
    Skokie, IL
    Did you buy it from an Audi dealer? And is it the original warranty or a CPO?
    Sep 04 2011
    Central NJ
    Did the dealer not know that when you called them about the warranty based on VIN before you purchased the car but now they know? I wonder if the previous owner knew and that is why he/she sold the car? Not sure if you would have much chance of recourse if you bought the car "as is."
    Nov 18 2016
    It was not an Audi dealer, but they did "specialize" in VW/Audi. They had a few s6's there and an s7 and a bunch of VW's. It was not CPO, but had remainder of factory warranty for another 8 months or 13k miles. I felt comfortable with that and was looking into aftermarket warranties for the long haul, as I purchased this primarily for my work.
    Nov 18 2016
    I asked my local dealer when they looked up the VIN for any weird issues or concerns and they said no. I didnt want to come out and say TD1, but they gave me the specific history and the exact date of warranty without any mention of a flag. Im going to go over there on my lunch and try to find out more and see what may be covered and what's not.
    I began to worry about the reason why someone got rid of this car weeks ago, but now it just confirms it - I picked up someone elses issue. I'd like to get these fixed, as it really is a clean, lower mileage, example. If other things are covered like, alternator, air suspension, electronics, etc - then I can deal with that, but if I lose everything, this thing will be dumped off to another dealer as a trade very soon.
    Veteran Member Four Rings zcd2.7t's Avatar
    Jan 19 2010
    MI/CA
    Theoretically, if you return the car back to stock (remove the flash(es) altogether), they should still honor the warranty, but I don't know how you'd get the OEM tune back onto the car unless the tuner kept a copy of the OEM file...
    2022 Tesla Model 3 Performance
    2023 Genesis GV60 Performance
    2015 Q5 TDi - Torque, baby!
    (Gone) 2013 S6, Glacier White over Black.
    (Gone, never forgotten) 2011 S4 Prestige S-tronic wSTaSIS stuff
