As the title states I can not start my car.
I just bought the car a week ago and drove it 850 miles home and started it plenty of times. Drove it to my brothers house last night and I come out to go start it and nothing happens. The EPC light is on as is the Check engine light. The battery light is also on. But we put the battery charger on it and put it on "jump start mode" and nothing still happens.
The vdo screen says push clutch to start. I am making sure the clutch is all the way to the floor. Still nothing. I unplug the upper clutch switch and jumper it and nothing still happens. I am getting 12.3 volts to the starter.
I was just wondering if anyone else has had this problem.
The car is up on jack stands right now and I am getting ready to pull the starter out.
I will try to clean the terminals on the starter and go from there.
Please help me so I don't start hating my S4 in less than a week of ownership.
I took the starter, alternator, and battery in and had them checked and tested. They all tested good.
I borrowed a friends VAG-com and read the following.
Thursday,17,November,2016,17:14:08:10805
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 16.8.3.1 (x64)
Data version: 20161010 DS267.0
www.Ross-Tech.com
Chassis Type: 8D - Audi A4/S4/RS4 B5 (1995 > 2002)
Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
Address 01: Engine Labels: 078-907-551-AZA.lbl
Part No: 8D0 907 551 M
Component: 2.7l V6/5VT G 0002
Coding: 06711
Shop #: WSC 87119
VCID: 3467D01E04115AE268-5140
1 Fault Found:
18010 - Power Supply Terminal 30
P1602 - 35-10 - Voltage too Low - Intermittent
Readiness: 0110 0100
Address 03: ABS Brakes Labels: 8D0-907-389.lbl
Part No: 8D0 907 389 E
Component: ABS/ESP allrad D56
Coding: 04395
Shop #: WSC 06435
VCID: 3561ED1A0F6B43EA5F-5122
No fault code found.
Address 08: Auto HVAC Labels: 8D0-820-043-1D.lbl
Part No: 8D0 820 043 P
Component: A4 KLIMAAUTOMAT D58
Coding: 00160
Shop #: WSC 63351
VCID: 2D51C57AE73B0B2A27-2592
3 Faults Found:
00779 - Outside Air Temp Sensor (G17)
30-00 - Open or Short to Plus
01273 - Fresh Air Blower (V2)
17-10 - Control Difference - Intermittent
01206 - Signal for Duration of Ignition Off Time
27-10 - Implausible Signal - Intermittent
Address 15: Airbags Labels: 8D0-959-655-AI8.lbl
Part No: 8D0 959 655 G
Component: Airbag Front+Kopf 2002
Coding: 00304
Shop #: WSC 63351
VCID: 3A7BFE262675AC92B2-5140
Address 17: Instruments Labels: 8D0-920-xxx-17.lbl
Part No: 8D0 920 981 B
Component: B5-KOMBIINSTR. VDO D12
Coding: 02264
Shop #: WSC 63351
VCID: 2B55CB62D92F051A39-5122
3 Faults Found:
00668 - Supply Voltage Terminal 30
53-10 - Supply Voltage Too Low - Intermittent
00562 - Sensor for Oil Level/Temperature (G266)
29-10 - Short to Ground - Intermittent
Address 35: Centr. Locks Labels: 8D0-862-257.lbl
Part No: 8L0 862 257 N
Component: CV-Pump, Alarm, RC D16
Coding: 16140
Shop #: WSC 63351
VCID: 408F8CCE40A9F642FC-4EEA
9 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01369 - Alarm triggered by Hood Switch
35-00 - -
01365 - Lock/Unlock Switch; Interior
29-00 - Short to Ground
00991 - Interior Lights
28-00 - Short to Plus
00955 - Key 1
09-00 - Adaptation Limit Surpassed
00956 - Key 2
Address 45: Inter. Monitor Labels: 4B0-951-173.lbl
Part No: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00101
Shop #: WSC 63351
VCID: 60CF6C4EE0699642DC-4B1A
Address 55: Headlight Range Labels: 4B0-907-357-AUT.lbl
Part No: 4B0 907 357
Component: LEUCHTWEITEREGLER D004
Coding: 00012
Shop #: WSC 63351
VCID: 65C17D5AFF4BF36A2F-5198
1 Fault Found:
01537 - Vehicle Level Sensor; Supply Voltage
31-00 - Open or Short to Ground
End-------------------------(Elapsed Time: 04:05)--------------------------
Address 01: DTCs cleared
Address 03: DTCs cleared
Address 08: DTCs cleared
Address 15: DTCs cleared
Address 17: DTCs cleared
Address 35: DTCs cleared
Address 45: DTCs cleared
Address 55: DTCs cleared
