Results 1 to 11 of 11
    Aug 13 2016
    New Jersey
    Lost functions on swapped steering wheel
    i REPLACED the steering wheel in my A3 with a S3 flat bottom wheel when i got the car- July 2016 - Just had a 5000 mile service and dealer did software upgrade. Lost all functions in wheel and lights. Dealer told me that it the software has to be upgraded again to this wheel but they cant do it because they dont have the codes since its a replaced wheel.is this true? Also- Any idea how much to get this done?
    Senior Member Two Rings Malv1's Avatar
    Nov 23 2012
    1995 Volvo 850 T-5 R
    Rochester Hills, MI
    Sounds like they ran an SVM update and it blew out the changes you made when you installed the new steering wheel. Who installed the steering wheel for you?
    - 2014 Glut S4 DSG. Stock
    - 2007 Imola RS4. Milltek catless, non resonated exhaust, APR tune, RS5 20" Rotors... SOLD
    Aug 13 2016
    New Jersey
    Local independent audi mechanic. I told him he says it may not work this time which I find hard to believe. How hard is it to redo and any thought on costs.
    Aug 13 2016
    New Jersey
    Nov 17 2014
    San Francisco, CA
    Do you have your old wheel? If so, swap out the controls from the old to the new S3 wheel. Should fix as it will be using the original equipment.
    Sent from my SM-N910V using Tapatalk
    Aug 13 2016
    New Jersey
    Quote Originally Posted by mroberte View Post
    Yes. I do. However the new wheel has paddles which aren't working either and old wheel doesn't have paddles.
    I will try that regardless and see what happens. I would imagine not hard to remove those
    Thanks
    Nov 17 2014
    San Francisco, CA
    Just change the front buttons... They are two pieces and the paddles will plug into them as well. Hope it works for you!
    Aug 13 2016
    New Jersey
    Thank you mroberte. Will let you know
    Aug 13 2016
    New Jersey
    UPDATE!! so the buttons are part of the entire inner ring. It is all one piece. I removed the inner ring of my old wheel. The started to pull airbag off of the new flat bottom already installed. Pulling the airbag off any of these steering wheels with the clips is not as easy a task as made out to be. WARNING! Anyone pulling airbag off!! Disconnect the battery first. Anyho. After finally getting airbag off ( whew) and pulling the inner ring off new flat bottom wheel and disconnecting all the connectors including the paddles LOL and behold- although the old wheel certainly had the connector locations for the paddles it most certainly did not have the female connectors. So! Time to put everything back together! WOA! What's this connector from all the wheel electrics to the car? DEALER NEVER CONNECTED IT! I did! Everything connected carefully replaced and guess what!!! Connected battery and EVERYTHING came back!!!! Now I'm in line for a dealer in central Jersey that actually has techs that have a clue!
    Nov 17 2014
    San Francisco, CA
    Glad you got it figured out and it was a rather "simple" but extensive fix. Enjoy those paddles!
    Aug 13 2016
    New Jersey
    Thank you again for all your help
