Hey guys,
I just had new Continental ExtremeContact DWS06 tires installed today, and had them do an alignment since it was a VW dealer with the proper equipment. So far it seems to be rolling with much less resistance than before.
Attached are the results. It seems as though they didn't have to change much, but mostly confused why my front left camber went from -0º57 to -1º01, while the right side stayed mostly the same. Shouldn't they be the same on both sides?
I'm assuming everything is fine because it's in the green, but just curious if my front alignment is almost worse off than it was before. There isn't much that I could find regarding what would be in/out of spec for my specific model - 2009 A4 Premium on the stock 225/50r17s
Thanks for your responses in advance! I know I ask basic questions, but I'm sure that I might not be the only one that doesn't quite understand.
