Results 1 to 13 of 13
    Veteran Member Three Rings 19jdog's Avatar
    Jul 28 2014
    2006 Mini Cooper s - 2013 Mini Cooper S - 2007 C6 Avant - 2006 GSXR 750
    SACRAMENTO
    3.0 timing question
    My cylinder heads were resurfaced. So I'm going to put my B6 back together tomorrow since I have the day off. All the valves are closed.
    Bentley
    Turn engine until cams (ARROWS) at intake and exhaust camshaft of #3 bank 1, point upward uniformly.
    Ok...
    What do I do for bank 2, drivers side? The Bentley doesn't say.
    11 Q7 Prestige TDI S Line - Stance SF 03 20x10
    04 B6 A4 USP 2.7t
    USP CLUB MEMBER #198
    BEL 2.7t SWAP- Rohana RC7 19x9.5 33mm - 034 REAR SWAYBAR - TIP TO 6 SPEED SWAP
    Veteran Member Three Rings cschuster's Avatar
    Jun 05 2013
    Lexington, KY
    Couldn't you leave the belt off, get the cam lock tool in place on each head...they only go on one way so you know its right, then put the belt on?
    Sent from my LG-H830 using Tapatalk
    2011 TTS
    APR Stage 1|H&R Rear Sway|Bilstein B12 Pro-Kit|42DD Downpipe
    2002 A4 Quattro 3.0 6spd - sold
    ST Coils|RS4 Reps|Rebuilt 01E|Color DIS
    Apr 07 2011
    Looks like you will do the same on the opposite side. Here's the ElsaWin version of the job. Click
    Jul 28 2014
    SACRAMENTO
    Quote Originally Posted by cschuster View Post
    They only go one way? You sure? I'm thinking I could rotate 180 degrees wrong direction. That's what I'm afraid of.
    Sent from my SM-N910P using Audizine mobile app
    04 B6 A4 USP 2.7t
    Jul 28 2014
    SACRAMENTO
    "Turn engine until cams -arrows- of intake
    and exhaust camshafts at cylinder No. 3
    (right-side cylinder bank) point upwards at
    equal angles"
    YES, so which cams will be pointing up on bank two??? #6?? That's my question.
    04 B6 A4 USP 2.7t
    Jun 05 2013
    Lexington, KY
    Quote Originally Posted by 19jdog View Post
    Hmmm, maybe. Its been too long since I did the timing belt. As long as your crank didnt move I think it would be fine. Follow the manual then try putting on the locks to confirm.
    2011 TTS
    Jul 28 2014
    SACRAMENTO
    This is how my B6 looks till tomorrow
    04 B6 A4 USP 2.7t
    Jun 05 2013
    Lexington, KY
    Dang, best of luck!
    2011 TTS
    Veteran Member Three Rings john_gonzo's Avatar
    Feb 03 2009
    Florida
    The cam lock tools go on only one way. The flats where the tools install on the cams are tapered. I think SJorge confirmed this but I haven't found the thread.
    Since cyl #3 is TDC on the compression stroke and firing order is 1-4-3-6-2-5, I'm guessing cyl #5 will be TDC (just ending exhaust stroke) and thus have both valves closed (cam lobes pointing up).
    Jan 09 2012
    MA
    Put the locking tools on before you put the heads on the block. Make sure the crank TDC position is set correctly and you will be ok.
    The directions don't mention the driver side cam position because they refer to when the engine is assembled and the belt is in place. If the passenger side is correct it follows that the driver must be in the correct position also.
    Jan 09 2012
    MA
    ps. if you have the extra cash available and they have not been changed in a while swap out those O2 sensors while they are right there in the open.
    Aug 27 2013
    Philly
    Quote Originally Posted by john_gonzo View Post
    Came here to say the same thing. Good luck with the reassembly!
    Feb 03 2009
    Florida
    If the cam lock tools make installing the heads a pain, these steps may be an option that avoids smashing valves:
    1. Rotate crankshaft until NO pistons are at TDC. This provides clearance for the valves later. A smart person would probably stop the crank about 90 degrees before TDC on Cyl #3.
    2. Install heads without cam lock tools.
    3. Install cam lock tools.
    4. Rotate crankshaft to TDC on Cyl #3.
    5. Install crankshaft lock pin.
