Results 1 to 6 of 6
    Veteran Member Four Rings boy412's Avatar
    Jul 15 2007
    2015 Golf Sportwagen TDI, 1988 Alpineweiß 325iC
    Mount Rainier, MD
    Weird climate control issue...blower is running hard but no air is coming out!
    Recently my climate control started doing something very strange. I don't drive this car often...and have noticed this both with the AC and the heat. Basically when I turn the system on (Auto) I can hear the fans blowing hard but no air is coming out of any of the vents. If I hit the re-circ button some flaps move around and I can feel air coming out. This also happens with defrost. Fans running hard but no air coming out of the dash vents. The defrost is actually the thing I'm most concerned about. That can be dangerous if your windscreen fogs up all of a sudden.
    I feel like the system needs to be reset or something so that it recognizes the flap positions, etc. I have VCDS and have run the output test. I hear flaps opening and closing during the test so I think all the servos are OK? Not sure what to check at this point. Any tips or suggestions?
    ~Eric
    SOLD: '03 Ming Blue A4 Avant 1.8TQM | GTRS | MTM cat/exhaust | Maestro | Spec Stage III+ | Vogtlant GT's | JHM trio | STE PPD | OEM+
    Veteran Member Four Rings imnuts's Avatar
    Aug 12 2009
    '21 F-150 Powerboost Lariat & '14 Acura RDX
    Dirty Jerz
    Scan the HVAC module for faults. Best guess is that the servos are stuck in position. You may be able to get by with just doing the re-alignment, but if you already tried that, you may be taking the dash apart a little bit to replace motors.
    Veteran Member Three Rings 5ktq's Avatar
    Aug 15 2016
    Western Canada
    There's a fresh air flap (right below cabin filter) and a cabin intake (behind glove box). Maybe both are shut (usually always one is open for intake).
    Jul 15 2007
    Mount Rainier, MD
    Quote Originally Posted by imnuts View Post
    Is there a procedure for a re-alignment or is this something the output test does? I'll scan the HVAC module again for faults. Can you tell me what "taking the dash apart a little bit" entails? Are we just talking about removing the glove box? I can handle that I think...
    ~Eric
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    You can realign the flappers with Vagcom.
    2019 SQ5 Prestige
    Jul 15 2007
    Mount Rainier, MD
    Quote Originally Posted by texasboy21 View Post
    Is this function in Basic Settings?
    ~Eric
