Results 1 to 11 of 11
    Junior Member One Ring
    Nov 17 2016
    ca
    Water pump and thermostat replaced, then more problems 4 months later...
    The thermostat and water pump on my 2013 S5 coupe (34,000 miles) was replaced in early July. The fix took 2 full days and as I was driving home, the check engine light came on almost immediately. I took the car back to the dealer and the next day they told me that they had put a vacuum hose(s) on backwards. Four months and 1,000 miles later, my husband smelled antifreeze and I took the car back in. This time they tell me the water reservoir is cracked, the water reservoir cap is bad and the A/C condenser is leaking. My question is: is this pure coincidence or is it possible that during the replacement of the water pump and thermostat, that they damaged these parts? Any insight would be welcome, thanks!
    Veteran Member Four Rings infinkc's Avatar
    Feb 14 2004
    S Ã C, CÃ*
    I say coincidence, the two are fairly far apart from one another. I havent heard of a coolant res cracking on the b8s before though. Does it look like physical damage? or from age?
    There are 10 kinds of people in this world, those who know binary and those who don't.
    Nov 17 2016
    ca
    They haven't gotten it fixed yet so I haven't seen it. I did ask them to keep the parts for me, though.
    Apr 05 2016
    Portland, OR
    If you're still under warranty take it back in as regardless of causality it should be covered.
    If you are out of warranty it might take some convincing. The damages are certainly plausible as the water pump and thermostat are pretty intrusive installs. (Albeit not in the same section of the engine)
    FWIW, I had one of my AC hoses installed backwards from the factory causing a slight water leak on my floorboard. Known issue with the early B8.5s and yet still took 4 trips to the dealer to get fixed
    I've had no issues in the 3 months since. (*knocking firmly on wood as my factory warranty period ends in a month)
    Geoff
    Nov 17 2016
    ca
    I am on extended warranty but that has a $200 deductible plus the cost of fluids. Antifreeze is about $60 (yikes) and I'm not sure what the Freon will cost me. What is really frustrating is that the first fix should have been under warranty but they said my car had been tuned and they would have to run it thought the extended warranty which cost me $260. I bought the car from them (certified used) and haven't done a thing to it. I don't doubt that it has been tuned, I just didn't realize it until they told me which of course was too late.
    I just remembered, I had my 35,000 mile service done at the same time. I think the following was done and would have thought they should have caught these problems then?
    Replace brake fluid
    Replace cabin air filter
    Replace engine oil & filter
    Replace multitronic transmission fluid
    Inspect battery
    Inspect brake system
    Inspect cooling system
    Inspect drive shaft boots
    Inspect exhaust system
    Inspect front and rear axle
    Inspect horn
    Inspect interior lights
    Inspect lights
    Inspect odb system check for codes
    Inspect plenum panel
    Inspect power steering fluid
    Inspect ribbed belts
    Inspect underbody
    Inspect wiper blades
    Inspect wiper, washer, headlight washer
    Inspect/lubricate door hinge mechanism
    Inspect/lubricate rear lid hinges
    Inspect/reset service reminder light
    Apr 05 2016
    Portland, OR
    You could do it yourself if you are a little mechanically inclined.
    Tank from ECS: https://www.ecstuning.com/b-assemble.../8k0121405nkt/
    You shouldn't have to drain the whole loop so I imagine a liter of G13 would be enough to refill the loop.
    Just in case you can grab some extra: https://www.ecstuning.com/b-genuine-...ers/g013a8j1g/
    Remember to dilute it.
    I haven't done anything with the AC but I doubt it will be cheap. This would be the only reason I would file a claim.
    Geoff
    Veteran Member Four Rings LYKUNO's Avatar
    Jul 18 2010
    NE Ohio
    Quote Originally Posted by sondra View Post
    I am on extended warranty but that has a $200 deductible plus the cost of fluids. Antifreeze is about $60 (yikes) and I'm not sure what the Freon will cost me. What is really frustrating is that the first fix should have been under warranty but they said my car had been tuned and they would have to run it thought the extended warranty which cost me $260. I bought the car from them (certified used) and haven't done a thing to it. I don't doubt that it has been tuned, I just didn't realize it until they told me which of course was too late. ...
    If you bought your car from an Audi dealer, I don't think they would have certified it (Certified Pre Owned) if it had previously been tuned. Here are the details for CPO from the Audi website. If it was indeed sold to you as CPO, then you should be covered for repairs (if within the time and mileage limits), unless you were the party to have the car tuned. Others can chime in if this information is not accurate.
    Edit to add the document that lists what's covered and what's not. The coolant tank should be covered as well as the A/C.
    2023 S5 Sportback | Prestige | District Green | Rotor Gray Napa | Sport Diff | Black Optics | Satin Bronze HRE RC104s
    Gone but not forgotten - 2011 S4 | Prestige | Jet Blue | HRE R40s
    Veteran Member Four Rings shadycrew31's Avatar
    May 27 2013
    West Chester, PA
    Quote Originally Posted by whiped View Post
    More than likely the drip line/pan was installed backwards, the AC lines are high pressure with specific fittings.
    Replace brake fluid
    This is all they actually did.
    Also I find it highly unlikely that the coolant tank is cracked. The Tstat replacement has nothing to do with the coolant tank you literally do not touch it besides filling it up and its a durable piece. There are however many O-rings, seals, and screws/bolts that all need to be torqued down properly otherwise you can have a slow leak. Might be worth taking it to an indy shop to have them diagnose, if you can prove its from the work they did it should be fixed for free by the dealer.
    2010 S4, DSG, too many random parts. 2004 Mazda RX-8, was highly modified then went back to stock.
    Jun 28 2016
    US
    From my experience, it wouldn't be the first time a "certified" Audi tech broke something else in the process of trying to fix something. These guys don't usually pay close attention to detail and will tear up other stuff while working from just pure inexperience or better said... lack of attention to detail. There hasn't ever been a single time I've gone to an Audi dealership or any other dealership for that matter where something wasn't put back on properly or something wasn't somehow damaged or scratched or dinged or what have you. It never fails... these guys turn wrenches like monkeys and just don't give a fuck about people's cars. Sometimes I wonder how they get away with it on much more expensive cars like the S8 or RS models or R models. Maybe those owners just don't know any better and don't care, but come on.
    May 27 2013
    West Chester, PA
    Quote Originally Posted by SwankP3RF3ct10n View Post
    I imagine there are specialized techs for those high $$$ cars.
    When I went to change my tstat recently there were two gaskets leftover from the previous install hanging out on top of the engine. Also three of the tstat bolts were finger tight, thats why I do my own work so I can blame myself and triple check everything.
    Jun 06 2016
    Florida
    I've changed the thermostat myself, it would be nearly impossible for the coolant reservoir or AC condenser to have gotten damaged during water pump/tstat change. You don't mess with either during removal/install of the water pump or tstat. Pure coincidence I'd say.
