Results 1 to 10 of 10
    Veteran Member Three Rings Euston's Avatar
    Oct 10 2016
    AudiB7S4Avant
    Yuma, Arizona
    Brake Light/Dead Battery
    Hi Guys, I've searched the Forums and the only brake related topics were locking or soft pedal...
    Has anyone had the brake depress just enough to activate the brake lights, leaving them on all night and waking up to a dead battery. I have since jumped and it fired up no problem. I have to physically pull the pedal with my hand to deactivate the brake lights and then if i close the driver side door, the slight bang though out the chassis is enough for the pedal to move down and turn the lights back on...
    Has anyone else had this? or heard of this?
    Is the spring that pushes the brake pedal back up shot? How would I diagnose it?
    Established Member Two Rings bwizard's Avatar
    Oct 10 2016
    Colorado Springs, Colorado
    Adjust the switch
    Sent from my S4's talk to text @ a buck thirty
    weekly driver 02 S4 2.7t auto stock
    Wife's 04 A4 1.8t auto stock
    Daughter's 97 A4 AEB Bored to 2.0t K04 sport cams
    My role family tech.
    Oct 10 2016
    AudiB7S4Avant
    Yuma, Arizona
    How do I do that? please and thank you
    Oct 10 2016
    Look up under pedals find the switch on the break pedal unplug it it should unscrew and have some sort of lock nut unscrew it a little lock nut back tight plug back in and test
    Oct 10 2016
    Or it could even be a clip of some sort bit should be adjustable you may have to also remove the kick panel if you don't see it
    Oct 10 2016
    AudiB7S4Avant
    Yuma, Arizona
    Thank you bwizard, I finally had some time to get under the steering column and found the actuator switch was dislodged ever so slightly.. took it out, checked it out fit it back and it's perfect.
    Oct 10 2016
    Your welcome
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    For future reference: Clicky clickŪ
    Jan 24 2010
    Paramus,NJ USA
    From what I know those switches are a one time install.No adjustment possible.Yes the pin could be reset.But IIRC they can only be installed once and correctly,otherwise they need to be replaced.There is something else that happens on the inside besides the pin being set to the correct point.Also on that note IIRC the brake light switches got updated to the green vw style switches and the brake pedal no longer needs to be depressed just push in and turn.
    Ziddy Autowerks
    Dec 28 2006
    Western Maryland
    Not true. If you put the switch in the unlocked position you can pull the plunger all the way up. Then simply install it the same way you would with a new switch. I've done it numerous times.
    Edit: For what it's worth I dissected my clutch pedal position switch to see if I could salvage it when it quit working properly. Nothing special inside. Just a set of contacts that engage/disengage depending upon the pin position.
    And thanks for the info on the new green style switches! I will look into that if I ever need a new clutch or brake pedal position switch.
