Results 1 to 7 of 7
Thread: Brake squel
    Jun 07 2016
    Atlanta GA
    Brake squel
    What's up everyone. A little while ago our 2013 Quattro started to produce a squeling sound when coming to a slow stop. It went in for service today, I asked them to check it out, and was told it is normal when the weather gets cold. Looking it up online it seems like a lot of people have had the issue, so far I have not seen anyone find a permanent solution for the issue. Anyone here used a specific brand of pads that might solve it?
    Thanks
    Apr 05 2016
    Portland, OR
    Every car I know of. Ugh. It drives me up the wall.
    rebedding the brakes will make it go away for a few days.
    Actual solution is to change pads.
    Geoff
    Jun 07 2016
    Atlanta GA
    Oh man that's what I was afraid of. Any recommendation what pads? Brembo? Someone said they put Akebonos and it stopped.
    Veteran Member Four Rings adamazing's Avatar
    Apr 26 2014
    San Diego, CA
    I've observed the same thing on my stock rotors/pads over the past two years. When the weather starts to cool down in Fall, the brake squeal starts to come alive. Just a fact of life with those pad compounds. Mine started coming back about 2-3 weeks ago. Most noticeably int he early mornings and evenings.
    It goes away once they're up to operating temps / hot.
    2013 A4 Quattro Green Black Iridescent / APR E85 Stage 2 / AG F421 Polished Copper / Eurocode FMIC + HFC / AWE Quad + CF Diffuser
    build / instagram / flickr
    Veteran Member Three Rings bat6wc's Avatar
    Nov 20 2016
    St. Louis, MO
    Glad to see Im not the only one with this issue. I bought the car used and I started hearing the squealing under light braking when the temperature dropped. It drives me insane!!!
    2016 A4 Quattro P+ S-line Appearance Pkg
    Senior Member Three Rings vdubtx's Avatar
    Nov 24 2014
    Rockwall, TX
    2018 S4 Prestige, Daytona Gray Pearl, Black Optic, S Sport, Napa Leather
    2012 A4 Premium Plus, Monsoon Gray, Quattro, Navi, Push Start. VCDS mods needle sweep, windows up/down with fob, no wink turns, fogs as cornering lights.
    Nov 20 2016
    St. Louis, MO
    Quote Originally Posted by vdubtx View Post
    Thank you! Ill be sure to talk to my dealer to see if this can be performed on mine.
