Results 1 to 30 of 30
    Active Member Two Rings baka's Avatar
    Nov 06 2016
    Bedfordshire, UK
    Can I change the Servotronic relay (controller) to lighten the steering?
    Hi, I know most people want the opposite effect but due to a crash years ago I need a car with light steering.
    The A4 B7 2.0TFSI Quattro S-Line I just bought is amazing, but I could do with the steering being a little lighter. It's got the 640 in at the minute.
    My old A4 B7 2.0TFSI SE had lighter steering, but I guess this could have been down to the narrower rubber and lighter wheels (215 on 16" vs 235 on 17")? Foolishly I didn't think to check the relay before I sold it.
    Nov 07 2015
    2004 Jeep Wrangler Rubicon, 94 Z28
    Pennsylvania
    Believe the relays for the s4 and rs4 give the steering a sportier feel. Unfortunately I think this is as light as you will get with out changing tires and such
    Sent from my Pixel using Audizine mobile app
    2006 A4 6MT - JHM Stage 2 93 Oct flash | Cam Follower Conversion | JHM HFC | JHM Downpipe | B6 S4 Exhaust | JHM HPFP Internals | JHM Small Core FMIC | 034 RSB | Sway Bar Endlinks
    Veteran Member Four Rings canadianA4B7's Avatar
    Feb 10 2012
    parts
    Napanee, ON
    I believe there is a difference in racks from A4 to s4 and rs4, just installed the S4 rack from a b6 S4. The relay from the rs4 is 628, which I have not yet tried. But the new rack makes a noticeable difference in feel, from what I've been told the rs4 relay wil make mine feel like the rs4.
    I think your not able to do what you would like. I believe it's as light as your gonna get.
    Nov 07 2015
    Pennsylvania
    You'll need the steering rack to make it feel like an rs4 too
    Nov 06 2016
    Bedfordshire, UK
    Thanks guys! I shall explore other options.
    Oct 23 2010
    2004 Atlas Gray A4 Avant
    Cranberry TWP, PA
    629 from a B6 A4 (not S4) should get you the lightest (most overboosted) steering wheel, FYI.
    2004 Atlas Gray B6 Avant, built 2.7T w/ BB K24's on E85
    2005 Touareg 4.2 gas guzzling daily
    2002 Triumph Daytona 955i
    1997 BMW M3 Coupe (sold, sad reacts only)
    Nov 07 2015
    Pennsylvania
    Honestly you can probably use a number of relays in that slot the higher will give you more steering boost but may wear out the servo faster.
    Feb 10 2012
    parts
    Napanee, ON
    Quote Originally Posted by Rulty View Post
    I'm gonna have to disagree. As I researched the shit out of the steering rack b4 I upgraded
    There is no RS4 rack. Been confirmed a hand full of times. The S4 and rs4 racks are the same. The rs4 has a servo relay that is 628.
    The only thing I did not confirm is the unit that the car plugs into on the rack. I have the A4 one removed, the S4 unit is in the car, the rs4 cars could have a different revision for this part. Wish I had taken a better look at the replacement rack. If so the relay in the car + the unit (controller maybe) on rack as a combo could be the answer to how the RS4 rack is the lowest ratio rack available.
    Ratios (these are likely incorrect as I don't have the actual data in front of me)
    A4 is 14.1:1
    S4 13.2:1
    RS4 12:1
    S4 is noticeably tighter, more feel to it and it seems to be much more responsive in and out of turns. This coupled with coilovers, 034 sway bar links, adjustable upper control arms may all be factors which have changed my car. But it's crazy how responsive it is.
    Oct 24 2015
    Perth, WA
    Im trying to understand how a relay can make any difference, it is either on or off.
    My respray thread
    Nov 07 2015
    Pennsylvania
    Wait how are they the servo rack then if they have different ratios?
    Senior Member Three Rings Van Black's Avatar
    Sep 07 2015
    Romania
    Quote Originally Posted by Okedokey View Post
    Doesn't the servo have a controller, not a relay?
    -Alex-
    07 A4 2.0 TFSI Quattro,Rebuilt engine, BPG pistons, S-Line interior, S-Line suspension, S4 brakes, RNS-E & Bose
    Oct 24 2015
    Perth, WA
    Yeah it does, but I am talking about relay to relay changes, not servo changes. I cannot see how a relay that is the same voltage and current can modify anything with the servo beyond on / off.
    My respray thread
    Jun 27 2011
    Well its not a basic relay. Thats why it costs $120 not $10...
    It has some sort of logic that alters the voltage going to the assist servo so alter the amount of assist it provides based on either wheel speed or gear/rpms. It would be interesting to see one disassembled.
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Feb 10 2012
    parts
    Napanee, ON
    When I buy the rs4 relay I'll gladly do this. To both the 640 and the assist device on rack.
    Nov 07 2015
    Pennsylvania
    http://www.rowand.net/Shop/Tech/AllAboutRelays.htm nice write up on relays and how they work in cars. Will give some insight as to why the 640 relay is different to the rs4 relay (forget the value) and that changes the way the servo responds.
    Oct 24 2015
    Perth, WA
    Nope. Its just a switch the only logic is on or off. The control module does what you describe. Thus my difficulty understanding how a relay could do anything different.
    My respray thread
    Jun 27 2011
    The relay IS the control module though. If t were a dumb on/off relay there couldn't be any difference between that and your average $5 fuel pump relay. I'm assuming the servotronic relay has some sort of PWM output to the steering rack servo or pump or wherever the assist is generated.
    I'm not sure how many stages of variable assist there are, but I would assume maybe 4 or 5 dependent on vehicle speed. Ask anyone who has swapped in an S4 or rs4 servotronic relay and the differences aren't in their heads.
    -CP
    2017 Q7 3.0t
    Oct 24 2015
    Perth, WA
    Nope, its just a relay, the servo is the motor that will be controlling the torque rate. A really cannot be PWM. The only thing I can think of is that the relay crossover voltage (coil impedance) may be different allowing it to engage earlier/later.
    My respray thread
    Jun 27 2011
    That's the solenoid. Maybe I was confusing your terminology?
    Are you saying that solenoid differs based on the car (a/s/rs)? Is that solenoid mounted on the rack?
    -CP
    2017 Q7 3.0t
    Oct 24 2015
    Perth, WA
    Thats a servo, a motor.
    My respray thread
    Jun 27 2011
    Oh jeeze. I guess I'm clueless about how servotronic works then, haha. I'll shut up!
    -CP
    2017 Q7 3.0t
    Oct 24 2015
    Perth, WA
    Nah man, I don't know either, could be completely wrong. I just cannot see the real benefit of the relay changes. It would be good to have some wiring schematics of the different relays including specs hey.
    My respray thread
    Oct 24 2015
    Perth, WA
    So I just read the training manual, the relay activates the ECU which controls the servotronics... again, not sure how this changes anything.
    My respray thread
    Oct 24 2015
    Perth, WA
    Ok, so I had a look at ElsaWIn. See below.
    Power is connected via the ignition switch to the Servotronic Control Unit (the relay - as you said).
    The relay then outputs to the solenoid valve (again, what you said)
    This would be a standard 12V on off except for the input from the ABS control unit speed signal.
    What I think is happening is that the final voltage that the solenoid sees is the net difference between 12V on the relay and the speed signal. (e.g. 12V +/- voltage from speed signal).
    So if the speed signal is outputting 6V, the potential difference on the solenoid would be 18V.
    However all of the above information goes into the ECU via the K line so I still believe that the ECU is doing the changes not the relay.
    Again, this still doesn't tell me how the relay would make a difference UNLESS there is a different resistance on the output side of the relay.
    My respray thread
    Jun 27 2011
    I didn't know ELSAWIN had wiring diagrams. I really need to acquire said software, my hardback Bentley is woefully out of date. In addition to being somewhat useless.
    -CP
    2017 Q7 3.0t
    Nov 07 2015
    Pennsylvania
    There are a lot of types of relays the most basic is on off switch controlled by the current. I'm not sure what the values on the relays are actually signifying but there are lots of relays. I imagine this type of relay controls the voltage based on the vehicle speed input...more assist at lower speeds....higher speeds change the voltage for less assist
    Oct 24 2015
    Perth, WA
    Except for the fact that relays don't do that and the wiring diagram doesn't allow for that anyway.
    My respray thread
    Jun 27 2011
    Some good info here. I believe it applies to the b7 system:
    http://www.audiworld.com/forums/a6-s...relay-1650870/
    And pictures of the circuit board inside one of them here:
    http://forums.quattroworld.com/s4s6/msgs/157312.phtml
    -CP
    2017 Q7 3.0t
    Oct 24 2015
    Perth, WA
    Well well, I stand corrected. Sorry about that.
    My respray thread
    Sep 07 2015
    Romania
    I can help you with that if you'd like
    -Alex-
