Results 1 to 12 of 12
    Apr 17 2012
    The Big O
    Eurodyne stage 2
    Any one experiencing misfires on there s3 running this tune? I have a 16' S3 I have also re-gapped the plugs still seems to miss at high rpm's.
    Established Member Two Rings Stam4765's Avatar
    Mar 06 2015
    Southern NH
    I had some misfires on their old tune (so did coolwater i think) but they fixed it a while ago. Im using Denso IKH24 plugs with a .024” +/- .002” gap and a high flow cat CTS DP with no spacers
    2015 Misano Red S3 | Eurodyne Stage 2 ECU/TCU | APR Intake | APR Turbo Muffler Delete | APR Catch Can | CTS Turbo Downpipe | 034 Rear Sway Bar | AirLift V2 Performace Air Ride Suspension
    Nov 06 2009
    2023 X3 M40
    NYC / DC/MD/VA
    Update to latest software and it should be good.
    -cW
    Sent from my SM-G935V using Tapatalk
    2023 X3 M40i Alpine White
    Apr 17 2012
    The Big O
    I am running v1.2 the newest version. But still on stock plugs I also am running a cts downpipe cat-less with the resonator delete. I'm thinking I'll just throw plugs at it see if it helps...
    May 21 2015
    Pacific NW
    I know this sounds like a bit of paranoia but I also had a misfire after switching directly to v1.1. So I reverted back to stock and then reinstalled v1.1 about 6 months ago. No misfires since. Runs flawlessly. I also have the Denso IKH 24 plugs with the tighter gaps. I just got the feeling that switching directly from V1.0 to v1.1 didn't really work. I could be wrong and maybe the misfire was just a fluke but switching back to stock first has worked for quite a while now.
    2015 S3
    2015 A6 3.0T
    2004 Allroad 2.7T
    2004 Lexus GX470
    2008 BMW 535xi (sold)
    2006 A3 2.0T (sold)
    Mar 06 2015
    Southern NH
    Quote Originally Posted by Nathing32 View Post
    you're not wrong i had the same experience. After I flashed to stock and did a full flash to v1.2 all my issues disappeared. This is after experiencing them consistently for around 2 months. When flashing from v1.0 to 1.1 or 1.2 it would seem fine at first then after a few days (depending on how much i drove) it would misfire again. Been solid for about 6 months now
    Apr 17 2012
    The Big O
    Just got my hands on a set of rs7 plugs so tonight I will be putting them in and also flashing back to stock and reloading v1.2 before heading out to fixxfest tomorrow. Wish me luck!
    Apr 17 2012
    The Big O
    Well put the new plugs in and went to the track, first run had a few misfires, second run a bunch followed by it jumping into limp home mode at about the 1/8 mile. So as I'm leaving the track I start to notice the sound of an exhaust leak thanks to a high curb I don't think much of it at the time as I'm upset my car is running like 💩. Got home tonight and decided to dig in, this all started after my downpipe install and res del. well as it turns out there is a leak in the exhaust as well as vacuum lines that were unplugged, and one of the wires going to into an enjctor was twisted and the pin was bent looks like the ship just jamed it back together. If that's not enough I found tools left behind from the tech and also a nut missing totally missing from my lower control. Needless too say I'm looking for a new shop at this point and they will be getting an earfull from me on Monday.
    Aug 08 2016
    Quote Originally Posted by Bbiddle87 View Post
    Jesus Christ people are so stupid. Sorry to hear about that. You should try to get a partial refund or something before you tell them you're done with them.
    Aug 08 2016
    Oh and keep the tools
    Active Member One Ring Certified S3's Avatar
    May 05 2016
    Boston/Mass/USA
    I had it bad then i upgraded the DSG software from 1.0 to 1.1 feels great now.
    Sent from my SM-G930T using Audizine mobile app
    May 05 2016
    Boston/Mass/USA
    Anytime you have issues with ED tune just email them....they replied fast and kept me in the loop until they udated the software. I have a 16 S3 and from wat i heard its a lil different then the earlier ones in terms of the software so there will be hiccups.
