Results 1 to 7 of 7
Thread: Broken cat
    Jun 20 2016
    Manchester, GA
    Broken cat
    I have a 99 B5 A4 Quattro 1.8t and the exhaust broke a couple of days ago right at the turbo outlet. Was wondering if I could replace with a test pipe, and keep the stock exhaust. Open to suggestions. Thanks
    Oct 10 2013
    98 Civic CX Hatch, 2012 CBR250R
    State College PA
    If your cat is Brocken then you should be able to slap a TP in there. You'll get a code bc of it but if you can live with it your fine. Also, need to make sure you can pass inspection without a cat.
    Dec 05 2007
    Broken cat
    Broken cat huh? Just grab it by the pussy.
    Too soon?
    Sorry...too hard to resist. I don't care for politics and didn't even vote. But answer in post above. You can first try spacing the rear o2 sensor out. many on the market. If that does not work, then code it out of the ECU (Nefmoto if all that you want is that).
    Veteran Member Four Rings ActiveMonkey's Avatar
    Jan 27 2006
    C7.5 A6 3.0T Prestige
    Orange County CA
    You could always take that part off and have it re-welded? But yes, a TP will bolt right in place of the cat.
    Current: 2016 Audi A6 3.0t Stage 2+
    Old: 2000 Audi S4 Stage 3 - SOLD | 2000 Audi S4 Stage 3 - Deceased | 2002 Audi S4 Avant - SOLD | 2000 Audi S4 - SOLD | 2003 Audi A4 - SOLD | 2001 Audi A4 Quattro - Deceased | 1998.5 Audi A4 Quattro 5MT - SOLD
    Registered User Four Rings XLR8 Craig's Avatar
    Feb 14 2014
    Audi's
    Branford, CT
    We carry 034 motorsports hfc option. This is a bolt on solution and will allow you to keep the stock exhaust.
    If you would like any more information on this product please let me know.
    Thanks,
    Alex.
    Jun 20 2016
    Manchester, GA
    Thanks everyone for the info very helpful. Emissions is no issue in the town I live in, and want to upgrade the a4 anyways. Just don't see the need to go back with a new cat.
    Sent from my VS987 using Audizine mobile app
    Veteran Member Four Rings xdewaynex's Avatar
    May 24 2009
    98.5 A4 1.8TQM
    Danville, KY
    Mine broke at the flange before and I just had it re welded. I have a test pipe I recently took off if youre interested.
    1998.5 A4 1.8TQM My Build
