Results 1 to 3 of 3
    Sep 12 2015
    Hong Kong
    Is it possible to get a similar sound like this on a v6 S5?
    Was wondering if it's possible to this similar sound with the cracking and gargling sound on a v6 S5 b8.5 similar to RS3. Coz this 350z is a v6 too!
    https://www.youtube.com/shared?ci=1Xa-qsEslK4
    Veteran Member Four Rings yjypm's Avatar
    Oct 08 2015
    I'm just guessing, the overall sound is close to awe exhaust. Maybe swap the x pipe for straight pipes?
    As for the lift throttle crackles it's a software tweak. I've asked Chris@EPL about this he said it would damage the cat.
    However recently I swapped a ported and polished throttle body on my car. The new throttle body doesn't get along well with my car and throws a CEL but it has some odd behaviors that actually make my s5 crackle after lifting throttle @~3200 rpm.
    Current: '18 M3 ZCP
    Mods: | E85 | BMS Intake | MPE | BBS Fi-R | Brembo GT F+R BBK |
    Sold: '14 Estoril Blue S5 P+
    | B&O | Sports Diff | B&W Nappa | Nav |
    Mods: | EPL 179/57+DSG | P&P TB | Revo SC Cooler | Ecode Head+Tail | ECS RS5 Front BBK | Macan Ducts | Brembo GT Rear BBK | AWE Touring | IE Intake | Bilstein B12 | USP Led kit | CR-15 | 034 Rear SB+Links | AluKruez | ECS Trans+Diff Inserts | Apikol Diff Mount | VCDS | P3 |
    Oct 08 2015
    Op I got two videos this evening but I'm not sure if you can hear the lift throttle crackles at 3000-3500 rpm.
    The sound doesn't happen on downshifting or revving in P or N, only occurs when lift throttle.
    This evening I put my car in M2 and lifted throttle at ~3400 rpm which is around 33mph (or ~53 km/h because the I used km/h on the center dash.
    I hope you can hear it a little because it was really not that obvious and i shot it in the car with the moonroof open.
    Current: '18 M3 ZCP
