Results 1 to 19 of 19
    Senior Member Two Rings projectvoltron's Avatar
    Apr 15 2012
    B6 Avant 2.7t, 2016 VW Tiguan
    Grand Junction, CO
    2001 S4 Won't start...EPC light on, Check engine light on and car won't even crank
    As the title states I can not start my car.
    I just bought the car a week ago and drove it 850 miles home and started it plenty of times. Drove it to my brothers house last night and I come out to go start it and nothing happens. The EPC light is on as is the Check engine light. The battery light is also on. But we put the battery charger on it and put it on "jump start mode" and nothing still happens.
    The vdo screen says push clutch to start. I am making sure the clutch is all the way to the floor. Still nothing. I unplug the upper clutch switch and jumper it and nothing still happens. I am getting 12.3 volts to the starter.
    I am borrowing a friends VAG com cable tomorrow so I will be able to read the codes then.
    I was just wondering if anyone else has had this problem.
    The car is up on jack stands right now and I am getting ready to pull the starter out.
    I will try to clean the terminals on the starter and go from there.
    Please help me so I don't start hating my S4 in less than a week of ownership.
    Jul 04 2012
    Woodbridge, VA
    As you already know, scan that sucker and let's see what codes you have
    Apr 15 2012
    Grand Junction, CO
    I will get it scanned and update tomorrow. Just got done cleaning the terminals on the battery and on the starter and still nothing.
    Mine was the clutch sensor
    Sent from my LGLS450 using Audizine mobile app
    Apr 15 2012
    Grand Junction, CO
    Quote Originally Posted by Cysco abt S4 View Post
    Did the epc light and cel come on when it was the switch?
    It will go off when it starts
    Apr 15 2012
    Grand Junction, CO
    Got the vag com and read the following codes
    I don't know what that means haha
    I took the starter off and alternator and am about to go to auto zone and have them checked
    Thursday,17,November,2016,17:14:08:10805
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
    VCDS Version: 16.8.3.1 (x64)
    Data version: 20161010 DS267.0
    www.Ross-Tech.com
    Chassis Type: 8D - Audi A4/S4/RS4 B5 (1995 > 2002)
    Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
    Address 01: Engine Labels: 078-907-551-AZA.lbl
    Part No: 8D0 907 551 M
    Component: 2.7l V6/5VT G 0002
    Coding: 06711
    Shop #: WSC 87119
    VCID: 3467D01E04115AE268-5140
    1 Fault Found:
    18010 - Power Supply Terminal 30
    P1602 - 35-10 - Voltage too Low - Intermittent
    Readiness: 0110 0100
    Address 03: ABS Brakes Labels: 8D0-907-389.lbl
    Part No: 8D0 907 389 E
    Component: ABS/ESP allrad D56
    Coding: 04395
    Shop #: WSC 06435
    VCID: 3561ED1A0F6B43EA5F-5122
    No fault code found.
    Address 08: Auto HVAC Labels: 8D0-820-043-1D.lbl
    Part No: 8D0 820 043 P
    Component: A4 KLIMAAUTOMAT D58
    Coding: 00160
    Shop #: WSC 63351
    VCID: 2D51C57AE73B0B2A27-2592
    3 Faults Found:
    00779 - Outside Air Temp Sensor (G17)
    30-00 - Open or Short to Plus
    01273 - Fresh Air Blower (V2)
    17-10 - Control Difference - Intermittent
    01206 - Signal for Duration of Ignition Off Time
    27-10 - Implausible Signal - Intermittent
    Address 15: Airbags Labels: 8D0-959-655-AI8.lbl
    Part No: 8D0 959 655 G
    Component: Airbag Front+Kopf 2002
    Coding: 00304
    Shop #: WSC 63351
    VCID: 3A7BFE262675AC92B2-5140
    Address 17: Instruments Labels: 8D0-920-xxx-17.lbl
    Part No: 8D0 920 981 B
    Component: B5-KOMBIINSTR. VDO D12
    Coding: 02264
    Shop #: WSC 63351
    VCID: 2B55CB62D92F051A39-5122
    3 Faults Found:
    00668 - Supply Voltage Terminal 30
    53-10 - Supply Voltage Too Low - Intermittent
    00562 - Sensor for Oil Level/Temperature (G266)
    29-10 - Short to Ground - Intermittent
    Address 35: Centr. Locks Labels: 8D0-862-257.lbl
    Part No: 8L0 862 257 N
    Component: CV-Pump, Alarm, RC D16
    Coding: 16140
    Shop #: WSC 63351
    VCID: 408F8CCE40A9F642FC-4EEA
    9 Faults Found:
    01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
    35-00 - -
    01371 - Alarm triggered by Door Contact Switch; Driver's Side
    35-00 - -
    01374 - Alarm triggered by Terminal 15
    35-00 - -
    01370 - Alarm triggered by Interior Monitoring
    35-00 - -
    01369 - Alarm triggered by Hood Switch
    35-00 - -
    01365 - Lock/Unlock Switch; Interior
    29-00 - Short to Ground
    00991 - Interior Lights
    28-00 - Short to Plus
    00955 - Key 1
    09-00 - Adaptation Limit Surpassed
    00956 - Key 2
    Address 45: Inter. Monitor Labels: 4B0-951-173.lbl
    Part No: 4B0 951 173
    Component: Innenraumueberw. D03
    Coding: 00101
    Shop #: WSC 63351
    VCID: 60CF6C4EE0699642DC-4B1A
    Address 55: Headlight Range Labels: 4B0-907-357-AUT.lbl
    Part No: 4B0 907 357
    Component: LEUCHTWEITEREGLER D004
    Coding: 00012
    Shop #: WSC 63351
    VCID: 65C17D5AFF4BF36A2F-5198
    1 Fault Found:
    01537 - Vehicle Level Sensor; Supply Voltage
    31-00 - Open or Short to Ground
    End-------------------------(Elapsed Time: 04:05)--------------------------
    Address 01: DTCs cleared
    Address 03: DTCs cleared
    Address 08: DTCs cleared
    Address 15: DTCs cleared
    Address 17: DTCs cleared
    Address 35: DTCs cleared
    Address 45: DTCs cleared
    Address 55: DTCs cleared
    Nov 16 2014
    ovid ny
    +1 on neutral safety switch
    When the key is turned all the way to start position it sends power to a relay via neutral safety switch. Other than that it's a direct link.
    I've bricked a ecu before and it would still crank
    Apr 15 2012
    Grand Junction, CO
    Quote Originally Posted by jimmer009 View Post
    Thats what I originally thought as well. Its the little black one on top right? I did the whole jumper thing with the plug using a paperclip once and a solid coper home wire and neither time it made a difference.
    I am starting to get a little frustrated as I took the battery in and had it tested and it came out fine. I took the starter in and had it tested and it worked fine. I took the alternator in to have it tested and it worked fine as well.
    It weird that I had this problem before at my parents house and we jumped it with my Dads chevy truck and it worked fine. But we could not jump it with my brothers tacoma or with the battery charger and "jump mode" which is 225 amps and bumped it up to like 16 volts.
    I tried to hardwire the starter off the car and It did nothing but at auto zone it worked just fine.
    Im confused
    Nov 16 2014
    ovid ny
    Well crap. The only thing it could be would be the wire to the starter. Or the key switch itself. I am really at a loss,
    You could try running a hot wire to the starter and use a push button switch. That would let you know if you ignition switch was bad.
    I am not 100% sure but think our cars will always crank. No matter what cel or code it's throwing.
    Apr 15 2012
    Grand Junction, CO
    It's not even cranking at all. I. Going to get a new battery tonight and just ordered a mew to me starter from audis4parts. Also got the oil level/temp sensor to get rid of that one fault code.
    If this stuff doesn't work I'm going for a new ignition switch
    I'm still going to try to jump the starter the way the previous post described. We will see!
    Current: 2011 A6 3.0t ibis/amaretto apr stage 2
    Traded: 2005 A4 Avant 2.7t
    Sold: 2001 noggy b5 s4
    RIP: 2004 B6 s4 sedan
    "It could be a number of things" -anyone who has diagnosed their Audi
    instagram @chasetophor
    Well I'm curious
    Bad fuse
    Bad cable
    Bad batt
    Bad alt
    Let us know for future reference
    Apr 15 2012
    Grand Junction, CO
    IT WAS THE GROUNDING STRAP!
    After all of that work I did I took the ground strap off and cleaned all the ends of everything involved and boom. Starts every time now.
    Since I have it apart I'm going to bake and paint the headlights black and remove the amber corners. I got some of the black chrome spray cover so hopefully it will still be able to reflect the brights. We will see.
    Thanks to everyone who chimed in and helped out.
    I feel like an idiot. But oh well it runs
    Oh sweet im so glad it was just a little tlc needed
    Ps i always get pulled over in grandjunction
    Apr 15 2012
    Grand Junction, CO
    Why do you get pulled over in junction.
    Actually now that you mention it I can see it. I got pulled over twice last week because I didn't have plates. One time was coming home from picking up the car. The other time was heading to the DMV to get plates.
    They always have a different reason
    Once for driving to slow after i almost hit an elk in the fog
    Once for doing windmills at trail through time
