Results 1 to 24 of 24
Thread: Power loss..
    Senior Member Two Rings jrow26's Avatar
    Apr 01 2016
    2007 Jeep Wrangler 4door
    GA
    Power loss..
    So I replaced my plugs and still have a p0171 error .. and power loss but only when I press the gas hard .. I can however get up to 100 miles an hour if I take my time getting there.. I pulled the plugs again and plugs 1-4 and 7 look like this
    And 5,6 and 8 look like this .. any thoughts ? Any Audi experts in the Louisiana / east Texas area Williams my to talk on the phone maybe stop but to help a new Audi owner?
    May 28 2013
    2002 Audi S4
    Shreveport, LA
    How are the coilpacks? Do you know exactly what that code is?
    May 28 2013
    2002 Audi S4
    Shreveport, LA
    Some specs on the car would be nice. Can't expect us to help you with little to no information. What kind of car? What's been done to it? How many miles? P0171 is a bank running lean. My guess would be it's got something to do with your injectors. Whether ones clogged or bad.
    Apr 01 2016
    GA
    I'm sorry I thought I posted this with my other post.. it's 2006 s4 4.2l v8 87,000 miles no mods to the eng. Oil Chang was done about 1 week ago. Changed the spark plugs last week and it's saying bank 1 was running lean (p0171). Coilpacks were changed around feb of this year.. I was originally getting the P0171 code along with p0300 random misfires.. and P0305, 0306, 0308 misfire codes but then changed the plugs and and now only get the P0171. I pulled the intake thinking I might have to do a carbon cleaning but to me it doesn't look bad
    Apr 01 2016
    GA
    Bump
    Active Member One Ring Sirphiladelphia's Avatar
    Nov 21 2016
    Philadelphia
    From what i am dealing with which is similar is a exhaust leak or post cat O2 sensors. With my luck i have both problems which i have to fix on my 2004 audi a6 quattro 4.2l.. A exhaust leak can trigger that code/multipile. Codes but its most likely you O2 sensors. A.k.a downstream sensor a.k.a post cat sensors
    Sent from my LG-K540 using Audizine mobile app
    Nov 21 2016
    Philadelphia
    There is also a O2 sensor in the engine as well.. Could be that also. Its a b**** to get to though.
    Apr 01 2016
    GA
    Wouldn't I get some sort of o2 sensor code though? And would it cause only certain cylinders to misfire or run lean?
    Nov 21 2016
    Philadelphia
    No my post o2 sensors or bad it say im running rich and i have no misfire. Ive had a misfire but it was spark plugs. Im not saying totally know but im not having them issues just wasting gas a lot.
    Nov 21 2016
    Philadelphia
    I have the power loss issue too.. Mine is due to lack of back pressure.
    Apr 01 2016
    GA
    Ok this might sound weird but when the car is idling the drivers side exhaust tip is pushing out exhaust normally but the passengers side sputters and doesn't push out as much exhaust as the left?
    Nov 21 2016
    Philadelphia
    Yeah i would go get a exhaust leak check on the left side at mineke its free to check. You could have a small leak somewhere. That will trigger bank 1 and 2 codes as well.
    Nov 21 2016
    Philadelphia
    My exhaust had so many leaks i had to remove the whole thing now im working on buying a whole new catback exhaust.
    Apr 01 2016
    GA
    Ok I'll check it out.. thanks a lot for answering..doesn't seem like this form is to active ..
    Nov 21 2016
    Philadelphia
    No problem. Let me know how it go if you get it fix.
    Apr 01 2016
    GA
    I will waiting on parts to come in ecs kinda screwed me didn't ship my parts 4 days after I ordered.. even though they showed in stock..
    Apr 01 2016
    GA
    Well it's back together.. still the same problem but now there is a rattle coming from the intake area and is shakes when you hold the rpms around 1200 at a stand still guess I'll take it to get the exhaust checked now that it's on it's wheels
    Apr 01 2016
    GA
    Rented a ob2 tester and no more P0171 code anymore now I have P0431..
    Nov 21 2016
    Philadelphia
    Im super curious what your problem may be. This saturday im getting a whole new exhaust put on and hopefully it fixes my problem.
    Nov 21 2016
    Philadelphia
    I got my exhaust installed. Gained my horsepower back. I have to check on the gas milage lasting long soon. But the codes are still ready. Im thinking it just may be the pre cat sensor. I have yet to reset the codes to see if it comes back. But so far.. My car is running like a champ.
    Apr 01 2016
    GA
    That's awesome I'm glad your exhaust worked .. I couldn't get my downpipes off so I ended up replacing the fuel filter and it did help but problems are still there I know get a bank 2 to rich code and misfires in 5,6, and 8 cylinders.. but only if I get on it it other then that it doesn't register any codes .. but I'm pretty sure I do have a slight misfire at idle .. I'm on Christmas leave in PA and decide to break down and have a Audi mechanic take a look at it.. maybe I can convince him to take my exhaust off and knock out the pre cats for me.. since I can't figure out the trick to getting the downpipes out
    Junior Member One Ring spiki's Avatar
    Nov 13 2016
    buffalo
    Hello I'm new to this site, I have a s4 b6 had the same issue. Po171 random misfire ect, I found an vacuum leak in the from under engine cover. However split and on load would run lean. Check that first and them spray intake to see if any other house maybe leaking. Also when you find a fix add a can of seafoam to gas tank and fill up. Hope this help it did for me. From one audi toanother. Good luck
    Sent from my VS990 using Audizine mobile app
    Active Member One Ring Jesse Sheridan's Avatar
    Oct 17 2016
    Quote Originally Posted by jrow26 View Post
    Have you found out what was wrong with your car yet?
    Sent from my SAMSUNG-SM-G890A using Audizine mobile app
    Apr 01 2016
    GA
    Yes I did finally after replacing the coils PCV valve and reseating the intake.. it got a little better.. although it was still misfiring and my long term fuel trims were -20 so I decided to replace the O2 sensors and since I was able to use a lift I removed the downpipes as well.. using a lift made it 100x easier.. only took me a hour a pipe. Once they were off I notice my bank2 pre cat was clogged and collapsing in.. so I gutted both replaced the O2 sensors and drove it...... it was like a whole new car.. actually felt faster then before when the car was running right... and my fuel mileage came back from 240 miles a tank to 330 miles..just purchased a JHM tune and will be installing it today to get rid of the check eng light for inefficient cats.
