Results 1 to 10 of 10
    Veteran Member Four Rings 88ninety9's Avatar
    Nov 02 2012
    Four rings and a long roof
    Indianapolis, in
    prop shaft adapter
    How many have used it? Opinions? My tip is shot so it's time to start a swap
    2002 Pearl/onyx S4 Avant
    Veteran Member Four Rings wbrunner23's Avatar
    Jun 07 2012
    1955 Johnson QD-16
    KSQ, PA
    I had to google to figure out what you were referencing - adapter to use auto prop with 01E. Looks like Mantis has some experience using an adapter with the swap.
    I'm assuming you already found his thread - http://www.audizine.com/forum/showth...IP-6-speed-DIY
    Veteran Member Four Rings erykv1's Avatar
    Jul 01 2014
    'murca
    better off just getting a manual drive shaft IMO.
    Nov 03 2011
    All Over!
    Quote Originally Posted by erykv1 View Post
    This is what I'd do as well. I'd only run a propshaft spacer if the correct one was super rare to come by. A manual B5 S4 propshaft is as common as muck.
    1986 Type 85 Audi 90 quattro
    Nov 02 2012
    Indianapolis, in
    Just weighing my options, looking for feedback. Chances are I'm going to get the manual propshaft. Especially if the adapter is that unheard of.
    That thread is the one that peaked my interest during my search
    Feb 27 2011
    Winnipeg
    I guess it depends how much the adapter is. I got a single piece shaft made for my tip so in the event I swap it I would buy the spacer, that being said I have a 6mt driveshaft in good shape sitting around for sale if shipping isnt too much.
    Aug 06 2008
    Canadia
    I would rock the adapter, most manual shafts are beat AF from ham-fisted shifting.
    the B5 S4 is like the mafia... there is only one way out!
    Nov 02 2012
    Indianapolis, in
    Quote Originally Posted by seanf86 View Post
    I'm sure shipping from Canada would go beyond what I could get one here for. I had plans to swap, just not this soon
    Quote Originally Posted by MacDaddy View Post
    This is one reason why I DON'T want to source a random used piece. I know mine is in good shape and don't intend on throwing any real power at it any time soon. Torn on anti-lag and nls as I know if I have it....I'll use it
    Also, time and funds permitted, plans are to have everything being swapped either new, or refinished.
    Still open to feedback from those who have used it.
    Jul 01 2014
    'murca
    I dont know of many people that have used that outside of that thread. Most people that do the tip to 6 speed swap just go with the 6mt driveshaft.
    If youre concerned about getting a beat shaft you can always replace the carrier bearing before installing it into your vehicle.
    Dec 04 2008
    5 audis and an f250
    Cresco PA
    after buying the piece repairing it and then either paying to have it put on or do it yourself, the spacer is probably cheaper. and in all reality will do the exact same job. its just like a wheel spacer...and millions of people use them as long as its balanced i doubt its doing anything wrong.
    Mine - Silver 01.5 S4 stage 2 - st - apr - ssac - apikol
    Wife - Imola 00 S4 stage 2 - st - ssac - podi - usp - 034
    Ours - Silver 92 S4 custom coilovers - 3 inch exhaust - ak motorsports
    Indigo Pearl 92 Coupe
    White 07 Q7
