Results 1 to 16 of 16
    Mar 04 2016
    MI
    FML, and this Car! Blowing thru coil packs same cylinder??!!
    Car is a 03' 3.0 V6 Auto Trans 205k miles. Nothing replaced other then coils plugs and fuel filter under 1500 miles ago. Cranks over easily just won't fire.
    I have no clue what is going on? If anyone saw my previous thread from awhile ago I had misfire issues. I changed all my coil packs and problem solved for a month?
    I had the same issues a few weeks ago. Bank 4 every time!! Changed coil pack, problem solved...Again. Bought an injector just to be sure. Started having problems week later. Got new injector, problem solved...Again.
    5 days later car starts up, runs fine. Go to town and shut car off. Come out 5 mins later won't start? WTF!! I start checking everything, everything looks fine. Changed coil pack in bank 4. Car starts right up?!?!?!?
    Today, leave for work. Car is running perfect. Starts right up. I forget something, run home. Shut car off. Run inside, back out 10seconds. CAR WON'T FUCKING START!!
    I miss work.. I am seriously about ready to call the junkyard and have them pick it up! Wires all look fine, I haven't changed the coil pack because I am so irritated right now. Plus its dark outside.
    Established Member Two Rings bwizard's Avatar
    Oct 10 2016
    Colorado Springs, Colorado
    Sounds like a wiring harness issue to me .
    Sent from my S4's talk to text @ a buck thirty
    weekly driver 02 S4 2.7t auto stock
    Wife's 04 A4 1.8t auto stock
    Daughter's 97 A4 AEB Bored to 2.0t K04 sport cams
    My role family tech.
    Jan 24 2010
    Paramus,NJ USA
    Need more information to help you.What engine whats transmission.Any recent work or repairs or parts replaced on the car???Also when you say wount start.Will it crank but not turn over or wount crank at all?
    Ziddy Autowerks
    Mar 04 2016
    MI
    Quote Originally Posted by EuroxS4 View Post
    Sorry, added info in OP.
    Jan 24 2010
    Paramus,NJ USA
    Ok do you have a vcds or anything to check for faults???The best way to diag this is to check everything needed to the car to start.So timing I will assume is fine otherwise you would have this issue everytime.Which leaves ignition and fuel.Has anyone been in the Ebox where the ecu is housed???I would inspect this closely.I have seen most people break the cover causing water to get to the relays and cause all sorts of issues.Also I would be checking the fuel pump relay and the pump.However because you say your burning up ignition coils and injectors which leads me to believe that either you have some bad grounds somewhere in the harness or going to the main ground on the engine or the ECM has some poor grounds or is shorting internally.There's alot to check there.But Being that your burning things up I would say most likely and electrical issue for sure.I would check the ebox for water intrusion and all ground on the engine,battery cables and so on.I would also check the crank position sensor and cam position sensors while your at it.
    Ziddy Autowerks
    Mar 04 2016
    MI
    Thanks EuroxS4. I do not have a VCDS but I do have a generic scanner. I will definitely check everything out tomorrow. As of right now it is pitch black outside and 37°F
    Jan 24 2010
    Paramus,NJ USA
    I hear ya same here in Jersey.But definitely check the ebox make sure you dont have any water getting in and go from there.
    Ziddy Autowerks
    Jun 27 2011
    Quote Originally Posted by bwizard View Post
    This. Wiring for sure. Peel back your coil pack plug boots and look for shredded, shorting wires. I bet you find some.
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Apr 01 2015
    2004 Audi A4 B6 3.0 Quattro, 2015 GMC Terrain, Infiniti G35 Coupe
    United States
    Check the wiring for that coil pack.
    Aug 27 2013
    Philly
    Does this car have ecu tune?
    Sent from my Nexus 6 using Tapatalk
    Veteran Member Three Rings 5ktq's Avatar
    Aug 15 2016
    Western Canada
    My money is on crank sensor, though it could definitely be something else. Eg power to coils. Do you have fuel /spark
    Aug 15 2016
    Western Canada
    Cause bad coil will just make it miss on that cyl, should still start fine
    Veteran Member Four Rings Gin+'s Avatar
    Apr 16 2015
    CNY Syracuse
    Your time line of events is really confusing to me. At what points did you have no start issues that related to failed coil or injector?
    Dec 05 2007
    Check your coolant temp logs. And the coil most likely just gets too hot and calls it quit...each time. Taking a guess!
    Suggestion of crank position sensor might be issue too. It is not ideal to throw parts at a car, in hopes to fix it. But this is one case where you can unless you can check oscillation. Try changing out your sensor. Search by the part number and you can cross reference a Bosch unit for cheap (ie I can source mine for like $25 shipped brand new Bosch).
    Mar 04 2016
    MI
    I'll try to me more clear.
    Car has been having issues bucking/missing when driving. Brand new spark plugs less then 1k miles and also fuel filter. I changed all 6 coil packs(Scan was showing Bank 4 misfire). Issue went away for about a month. Started happening again, I changed coil pack in bank 4(As it said again, bank 4 misfire).
    Less then a week later same problem, bucking/misfire while driving around 60mph. At this time I bought an Injector as I thought it was getting plugged. I changed the Injector. Problem went away for about 4 days.
    Then I had the issue were it wouldn't start when I was in town(New injector was installed and coil already at this time). I replaced the coil and checked the plug. Car fired right up.
    Flash forward to today, Car fired right up? I didn't change anything? I'm wondering if Seerlah has it right and somethings getting hot and shutting off? Car runs fine until I shut down and try and restart. But as of now the car is being parked for the winter. I can't deal with it dying on me in -30+ degree weather.
    Dec 05 2007
    I would focus on 4 main things. This is what I would focus on if it were me, and they were all mentioned:
    1) Look into your coolant temp sensors. Your needle may be saying one thing...but your ECM can be seeing something else. Research what temp it is supposed to be for the B6 (I don't own a B6), and see if it is in spec. If not, replace it. This has to do with your fueling calculations, and your symptoms match that when they are bad...such as the car not starting all the time. But not so much with the ignition coil blowing constantly on cylinder 4. Could be related...could be unrelated. We'll take this steps at a time.
    2) Your crank position sensor could also be the issue. This item is hard to test without just swapping out. But you can take it out, see if it has metal shavings on it (it is a big magnet that senses crank position by gaps in the tone ring on the crankshaft), and clean it off it does. I would actually try this first and soon (like...right after you read this post if you have the time), because it is free. Take it out and clean the crap off the magnetic part. ECM uses this for ignition timing, which could also be why your car won't start and misfires. If too many shavings, ECM is basically confused and won't start the car. We will hold off on ordering this right now, while we test other free fix-its in the mean time.
    These sensors suck because it isn't necessarily a work one day and not the next item. It will make your car doing "exactly" what it is doing now, then one day it will give you a DTC and then it will give out on you. How long it plays tricks on you till it givers out...never know. It can also just give out immediately. Very highly cause of your issue, so try taking it out and inspecting for shavings on the then. Wipe the end regardless and place it back in. Very tiny shavings eventually accumulate onto it, and that can most def be causing your problems.
    3) Extra resistance can be created by corrosion for cylinder 4. Resistance makes the amp draw of the ignition coil more than it should be, making it more hot. Next thing you know...it burns out. Peel back the rubber boot on the engine harness side and look for anything that is a short (ie corrosion, wires exposed, etc). Not sure on the 30v, but the 20v has 4 wires. Two will be ground, one for each positive wire (4 in total). One is a constant 12v when key in starting position or car running. Other is a 5v signal. We will confirm proper voltage later if these have the same wires and voltage as the 1.8T 20v.
    4) Not mentioned but could also be the culprit is the cam position sensor. Car will run, but sometimes takes more cranks for this to happen. But car will run on the 20v totally unplugged (confirmed this myself before). Apples to oranges because different management systems and engines, but taking a stab in the dark.
    You also need to know that as you are turning the engine with no engine start, you are also flooding the cylinders with gasoline. So if the car won't start after multiple turns, your spark plugs are already saturated and they will need to dry before trying again. I would conjecture this happened without you knowing, but still is not the main reason of your issue. More like a domino effect that needs to be addressed.
    I tested airing out the plugs on my car before with gas to the floor (2001 AWM) and it does not work. Car started and RPMS flew up with an unexpected start of the engine (yeah, wasn't happy with results when car started...lol). To air them out (dry them), undo the injectors (or fuel pump...but you still have all that fuel in your feed line. undo injector connectors preferably) and turn the engine. The intake air will pass over them without fuel spraying and dry off your spark plug. Then start over with plugs dry and able to create a spark for the engine to start.
    If you don't have money for the full version of Ross Tech software, you can download the Torque app on your cell phone. I used this all the time. Then get a bluetooth OBD II reader to use it. It will cost you $20 max all said and done, and can be done for half that if craft. What will cost the most is the Torque app (don't use lite, and pay for the full version) and is like $5 or so. But it is well worth the money. You can use this for diagnosing of your coolant temp and such. You can actually use it for most of your diagnosing. I have the Eurodyne Suite and had VSDS before that. When I switched to the Suite, I sold my laptop with the Ross Tech software. Even though I have Eurodyne Suite, I find myself using this Torque app for just about all things that require fault code scanning and parameters that it is capable of reading. It can also be used on all cars, which is a plus (I use this for friend's cars when necessary, along with my back up car).
