Results 1 to 4 of 4
    Jan 12 2016
    Los Angeles, California
    How difficult would it be to install a new downpipe myself?
    I have an AWE downpipe coming, and I have full access to an automotive repair shop, how difficult would it be for me to change the downpipe myself? What major parts have to be removed? How long should it take?
    Thank you in advance,
    Kevin M.
    2016 Monsoon Grey S3 P+ w/ BO, Resonator Delete, AWE Resonated Catted DP, Unibrace UBQ, 034 Rear Sway Bar, 034 Dogbone Insert, 034 Rear Subframe Inserts, 034 P34 Intake, CTS Turbo Inlet, ED Springs, Eurodyne ECU and TCU
    Established Member Two Rings MathildaS3's Avatar
    Apr 14 2015
    Palm Beach Gardens, FL
    Check VWV. Someone just did it.
    2016 Sepang Blue S3. MagRide, SuperSport seats, B&O, RS3 grille, wheel spacers 10mm/17.5mm, K&N drop-in filter, stock intake mod, LED interiors, Spulen engine mount insert (modified), BMS JB4 tune. Sleeper AF...
    Established Member Two Rings Z32drifter's Avatar
    Mar 04 2016
    94 300zx weekend/track toy
    Orlando. Fl
    It's not that hard. You have to unbolt the drive shaft and move it to the side. The bracket supporting the factory down pipe is a chore to remove. I think with basic skills 3 hours should be enough time to install it.
    Mar 11 2007
    1990 R32 GT-R
    Somewhere in CT
    Quote Originally Posted by Z32drifter View Post
    LOL budget more time than 3 hours, from personal experience.
