Results 1 to 16 of 16
    Veteran Member Four Rings MCT9891's Avatar
    Jul 06 2009
    2008 VW Jetta Wolfsburg 2.0T 6DSG
    Staten Island, NY
    P0420 and Smoke!
    So the car threw a P0420 code, which probably means the cat is bad, but I noticed smoke coming from the right side of the cat.
    Here's a video...
    You think it's from the cat being really plugged up? I passed inspection about 2 weeks ago... and I got the code this past Saturday.
    Veteran Member Four Rings MurkyRivers_A4's Avatar
    Dec 17 2009
    Tools, boxes of random car parts, 55 gal drum of used oil
    Kentucky
    Got any oil dripping on to the cat from the VC gasket?
    2015 Daytona Grey Audi S4 | DSG
    2013 Ibis White Audi A4 | Tip
    2006 Brilliant Black A4 Titanium | 6 speed
    Jul 06 2009
    Staten Island, NY
    Quote Originally Posted by MurkyRivers_A4 View Post
    Not that I can see but the gaskets are definitely leaking.
    Dec 17 2009
    Kentucky
    Quote Originally Posted by MCT9891 View Post
    That was my issue with the smoke and smell. The VC gasket was leaking oil onto the exhaust mani and seeping through the gasket, I believe.
    Jul 06 2009
    Staten Island, NY
    Just hoping the smoke isn't coming from the cat itself but I don't think it is.
    Dec 17 2009
    Kentucky
    The only way the cat would be smoking is if it was burning off oil that was getting to it. I dont even thing when they get clogged they smoke. They just get really fucking hot.
    Jul 06 2009
    Staten Island, NY
    Ok, it does cause damage to the turbo if it's clogged though, right?
    Dec 17 2009
    Kentucky
    If it gets hot enough Im sure it can coke up the oil. If its clogged, its only going to allow so much air through and the turbo will not be able to create as much pressure as fast.
    Mine was clogged and it ran like shit. I gutted it, problem was solved.
    Jul 06 2009
    Staten Island, NY
    What did you use to gut it?
    Dec 17 2009
    Kentucky
    A large screwdriver and a hammer. Mine had been clogged for some time before I bought the car and it was pretty much solid. It took me 2.5 hours and a lot of cussing.
    Jul 06 2009
    Staten Island, NY
    Lol ok that's what I'll probably end up doing.
    Thanks man
    Dec 17 2009
    Kentucky
    Thanks man
    Before you go gut crazy, inspect it first. Check to see if the catalyst has moved at all or if there is visible damage, like there was to mine. No point in ruining a good cat if you dont need to.
    Jul 06 2009
    Staten Island, NY
    Yeah I will, thanks.
    Jul 06 2009
    Staten Island, NY
    How long is the actual catalyst and how far deep into the cat is it?
    Dec 17 2009
    Kentucky
    Its a two piece catalyst, at least it was for mine, and it goes pretty deep. I had a 12" screwdriver and it wasnt quite long enough once I got to the end. I needed to use a tire iron, which was even less fun.
    Jul 06 2009
    Staten Island, NY
    Ok thanks again.
