A common issue on lowered Audis equipped with AFS (Adaptive Front-lighting System) headlights is the adaptive headlight sensors inability to compensate for the change in suspension geometry. This typically results in an adaptive headlight system error illuminating on your gauge cluster. This error causes headlight beams to end up pointing down at the pavement providing you with poor nighttime visibility.
ECS Tuning's R&D department has engineered an Adjustable Headlight Leveling Sensor Bracket Kit as a solution.
Get Level
Fitment:
Audi B8/B8.5 S5 2008-2016
Audi B8 A5 2008-2016
Be sure to check out our -----> Installation PDF <-----
Jason
