    Veteran Member Three Rings swaggerwagon's Avatar
    Sep 28 2012
    NC
    T-Stat Housing Crack
    Any of you guys ran into this issue? I was pissing coolant all over the place yesterday and was able to pinpoint it to what looks like a crack in the T-Stat housing. Had the same issue last year with a Ford. T-Stat has 70k miles on it.
    B8.5 3.0T/ B5.5 1.8T
    Senior Member Two Rings drmonkey's Avatar
    Sep 04 2015
    Clear Lake, TX
    Well the thermostat is a solid piece with the plastic housing that the hoses attach to. They're pretty easy to replace.
    Sep 28 2012
    NC
    I have the part on hand. Just need to carve out time to do it.
    Feb 15 2016
    Cambridge,Ontario
    wow never see one actually crack .. but to be honest they are terribly unreliable and usually get replaced long before the plastic starts to fatigue. So I would say you had a pretty good run.
    now the coolant manifold is a different matter . that thing usually just crumbles and starts pissing all over your gear box.
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Jan 24 2012
    Connecticut
    Pretty common. Mine did the same thing last winter.
