Results 1 to 12 of 12
    Dec 30 2013
    Australia
    Is it normal for Oil Cooler Coolant hoses to have a slight bulge in them?
    Is it normal for Oil Cooler Coolant hoses to have a slight bulge in them coming off the oil cooler? Similar to the pic below
    Nov 15 2016
    Nj
    It may not be normal but if it's not causing leaks or it's not cracked it shouldn't be much of a problem
    Oct 10 2013
    98 Civic CX Hatch, 2012 CBR250R
    State College PA
    It's old and about to go. May wanna get that fixed before it goes while your driving.
    Veteran Member Four Rings ActiveMonkey's Avatar
    Jan 27 2006
    C7.5 A6 3.0T Prestige
    Orange County CA
    I've always gone with this saying and its helped me never have a hose pop on me.
    "When in doubt swap it out"
    Current: 2016 Audi A6 3.0t Stage 2+
    Old: 2000 Audi S4 Stage 3 - SOLD | 2000 Audi S4 Stage 3 - Deceased | 2002 Audi S4 Avant - SOLD | 2000 Audi S4 - SOLD | 2003 Audi A4 - SOLD | 2001 Audi A4 Quattro - Deceased | 1998.5 Audi A4 Quattro 5MT - SOLD
    Established Member Two Rings bwizard's Avatar
    Oct 10 2016
    Colorado Springs, Colorado
    Get it hot wear ppe push on the bulge with an ink pin the sharp end if it pops it needs replaced. Just kidding just replace it it's about to blow.
    Sent from my S4's talk to text @ a buck thirty
    weekly driver 02 S4 2.7t auto stock
    Wife's 04 A4 1.8t auto stock
    Daughter's 97 A4 AEB Bored to 2.0t K04 sport cams
    My role family tech.
    Senior Member Three Rings dalazybastard's Avatar
    Apr 08 2016
    Orange County, CA
    I'm dying. Seriously, don't forget PPE.
    Just a couple B5's, you know.
    Dec 30 2013
    Australia
    Thanks for the replies. Does a shitload of coolant spill out when you pull these hoses off? As in do you have to drain the whole coolant system before replacing these hoses?
    Veteran Member Three Rings kwnk's Avatar
    May 21 2011
    '03 SV650S, '76 280z
    Yes a bunch of coolant will spill out if you remove those hoses. I dont think they can be clamped off either since one of them connects to the upper hard pipe
    1999 1.8TQM Avant | H&R Coilovers | 034 1bar tune | 16" URS4 Fuchs | Forge 008 | Borla
    Apr 08 2016
    Orange County, CA
    The oil cooler is an water to oil system, so yes a bunch of coolant will spill out.
    You could remove all of it beforehand or just do the job(losing however much you lose) and do a coolant flush(with distilled water) after.
    Regardless after either job top off with g12 and distilled water to make 50:50 mix or whatever you desire.
    Dec 30 2013
    Australia
    Does anyone know approx. how many litres come out disconnecting these hoses?
    Jun 30 2008
    Erie, Pennsylvania
    Approximately all of the liters.
    Veteran Member Four Rings Cgoon009's Avatar
    Mar 02 2013
    I have a garage? Do tell...
    DC
    Quote Originally Posted by OldAudiA4 View Post
    You should plan to drain and bleed the system, while your there, you may as well flush and add all new coolant. Now would also be a great time to examine any other hoses, areas of leaks, sensors, etc. that may be about go as well. If the coolant was recently replaced, then save it, but be sure to filter it so nothing other then coolant makes it back into your system.
    Eurosport Tuning at it's Finest
