Results 1 to 6 of 6
    Veteran Member Three Rings windyctyaudi's Avatar
    Jul 30 2007
    '12 S4 prestige DSG
    Chicago
    Damage to coolant line from aftermarket intake
    It's been awhile since I've been on here, but I was wondering if anyone else experienced damage to their coolant line from their roc euro intake or another similar intake. I've had the intake for about 50k and clean the filter every 5k. Today I took it off because I was taking my car in for service and noticed the coolant line behind the intake pipe looks like it has been grinded down from rubbing on the pipe. I completely remove the intake every 10k when I take my car in for service and this is the first time I've noticed any issues. I don't think I will be putting it back on.1479275741783.jpg1479275797369.jpg
    Sent from my Pixel XL using Audizine mobile app
    Veteran Member Three Rings LordMagnet's Avatar
    Jul 20 2015
    Connecticut
    Lots of people experienced this, including myself. Annoying but easily fixed (the grinding, not the line).
    http://www.audizine.com/forum/showth...d-their-intake
    http://www.audizine.com/forum/showth...p-with-RocEuro
    http://www.audizine.com/forum/showth...ke-help-please
    2015 Audi S5 Coupe 6MT | Mythos Black Metallic : Black Nappa : Alu-Optic : B&O : Sport Diff. : 19" RS Rims : Carbon Fiber Inlay | APR Stage 2 : Roc-Euro Intake : AWE Touring Exhaust 102mm : EuroCode Short Shifter : USP Clutch Line : CR-15 Strut Tower Brace : 034 Mounts : H&R OE Sport Springs : 15mm/20mm Spacers : Tint 35% Sides / 20% Rear : Interior LED Kit : E-Codes : Vinyled Grille | 413 AWHP / 375 AWTQ
    Established Member Two Rings BB c7's Avatar
    Jan 23 2016
    Chicago
    Ooh i have to check mine. Thank 4 sharing
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    Glad you caught it before it was able to leave you stranded!
    This is generally regarded as an installation error, or due to the clamp at the throttle body not being tight enough which results in the intake pipe rotating over time and eventually resting and rubbing on the coolant line. For added safety, you can buy a small piece of rubber hose and wrap it around the pipe as seen here.
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Veteran Member Four Rings A.C.'s Avatar
    Sep 15 2013
    2015 VW GSW TDI, 2004 GLI, 2015 Kia Sorento
    MD
    Quote Originally Posted by LINDW4LL View Post
    Yep. That's what I did before I installed my CTS turbo intake. Excellent tip
    Jul 30 2007
    '12 S4 prestige DSG
    Chicago
    Thanks for the help guys
