Hello,
For the past few month I have had difficulty changing gear. I can disengage the gear easily, but is very difficult to engage a gear (needs to be forcefully pushed in). This is particularly difficult when at high RPM (need to give it several seconds for the RPM to go down to <2000rpm).
I need your help to figure out what is going on.
Let's start with the basics: 2008 RS4; about 42k miles; clutch/flywheel/pressure plate changed about 18 months ago (12k miles ago) with the JHM Stage 1R combo.
Two years ago I experienced about the same thing (difficulty shifting), and the Audi dealership pointed out to the clutch disk and pressure plate (OEM at that time). This is when I decided to upgrade to the JHM 1R. After the new clutch install, everything was fine for a bit more than a year.
Now I am back to having trouble shifting, and took the car to my mechanic. The expectation was that some bolts on the pressure plate came loose, not allowing it to disengage fully. Taking the clutch apart, it was found NOT to be the case. At this point, my mechanics does not know what is causing the problem, and this is why I need help from the community to figure that one out.
* According to my mechanic, the clutch can slide on the shaft without problem (no apparent scratch mark on the shaft or any kind of blockage).
* The primary and slave cylinders were NOT replaced when the Stage 1R was put in.
* It it noteworthy to point out that both the clutch disk and the flywheel are showing significant hot spots (see picture). I think this is the consequence of my problem, and not the cause of it...but I am sure of nothing at this point.
Any help and guidance would be greatly appreciated!
J.
