Results 1 to 8 of 8
Thread: Soundaktor
    Senior Member Two Rings unasupra97's Avatar
    Sep 28 2016
    nj
    Soundaktor
    Saw online to remove the fuse to deactivate the soundaktor when installing a cat back..is that only for cars with ads or does it apply to all?
    Sent from my SM-G935T using Tapatalk
    Veteran Member Four Rings XxSullyxX123's Avatar
    Mar 04 2015
    2020 Jeep Unlimited Wrangler Rubicon Recon, 2023 Honda Pilot Elite
    Somers, NY, USA
    All B8.5 models I believe. 2013+.
    2016 S4 P+ | Mythos Black | DSG | Blk Optic Pkg | Blk Nappa Leather | Tech Pkg | B&O | Carbon Inlays | Supercharged Badges ||| - SOLD
    2015 S4 P+ | Monsoon Grey | 6MT | Blk Optic Pkg | Blk Nappa Leather | Tech Pkg | Supercharged Badges | AudiGuard ||| - SOLD
    Sep 28 2016
    nj
    Thanks for the info..will be pulling it tommorow
    Mar 21 2015
    Quote Originally Posted by unasupra97 View Post
    You can turn it off with vcds too instead of pulling the fuse. You'll get some soft codes by pulling the fuse but nothing to worry about.
    Veteran Member Four Rings LittleDozer's Avatar
    Jan 21 2014
    C5 RS6, D4 S8, 2016 XC60
    Minneapolis, Minnesota
    I pulled it when putting a Stasis setup on. You'd be amazed how much sound that thing was pumping through the car.
    Sep 28 2016
    nj
    Good to know ill see if my buddy can do that for me next time i see him
    Sep 28 2016
    nj
    Quote Originally Posted by LittleDozer View Post
    Yeah i just installed the cts catback and it drones like crazy trying to find a used set of awe resonated downpipes to see if that helps [dsg]
    Mar 04 2015
    Somers, NY, USA
    If you haven't pulled the fuse, that could Be creating drone layered on top of the exhaust frequency. That's why AWE says pull it. It's really easy to do. Takes 2 Minutes
