Results 1 to 7 of 7
    Active Member One Ring Wide_B8's Avatar
    Nov 13 2016
    Pennsylvania
    Rear air bag set up
    I'm having a problem figuring out how the rear bag mounts for my d2 racing air suspension any help would be great thank you
    Sent from my SM-G935V using Audizine mobile app
    Veteran Member Four Rings earhythmic's Avatar
    Sep 17 2006
    ‘17 F450, ‘24 Street Triple RS
    San Francisco Bay Area
    Is the first pic the top or bottom orientation? There's typically a nut that goes into the frame of the car from where the old spring perch used to be. To tighten the nut you have to take an angle grinder to an existing hole to gain access. Did it come with instructions? Maybe reference the B8 Airlift install guide, it's pretty detailed
    2013 Allroad - 12.18s 1/4 mile
    CTS K04| APR | IE | Magnaflow | AirLift 3H | Hotchkis | Vorsteiner
    clicky for build thread
    past: B6 S4, B5 A4
    Nov 13 2016
    Pennsylvania
    No the manufacturer forgot the instructions and I've been playing hell to get they to send me a pdf and that's what I don't know if that's top or bottom of the set up and what that plate would be
    Veteran Member Four Rings awdconnor's Avatar
    Jun 07 2016
    Portland, Oregon
    interesting.. never seen d2 on our cars..
    [COLOR="#808080"][FONT=System][SIZE=2]2018 Audi S4 P+ | 034 Stage 2 E85 | Airlift 3P | BBS RSii
    Nov 13 2016
    Pennsylvania
    They offered me 45% off so I figured I would give them a try
    Sep 17 2006
    My money is on the first picture being the top since it has the little nub that fits into the OEM spring perch hole. Plus it would be idiotic of them to have the airline connection on the bottom and move around with the control arm. Look at page 7 and 8 of the airlift manual, it'll show you the orientation: http://www.airliftcompany.com/conten...als/MN-873.pdf
    past: B6 S4, B5 A4
    Nov 13 2016
    Pennsylvania
    That's the photos the company sent me like the air does go from bottom but like you said that doesn't make sense and they are no help at all
