Results 1 to 37 of 37
    Active Member Four Rings S4orgy's Avatar
    Nov 11 2008
    05' B6 S4 B.R. 2000 B5 2.8 B.B.
    New Britain/Farmington, CT
    B6 s4 Feeler $20k 101k miles
    Testing the waters on my s4. Losing interest in the s4 game and would like to get into something else thats better on gas and draw less attention.
    Mods.
    *jhm 93 oct tune
    *jhm ported manifold w/spacers
    *lightweight flywheel w/stg3 clutch
    *jhm lightweight crank pulley
    *jhm short shifter
    *2.5" A.W.E catless downpipes
    *Corsa 2.5 non res exhaust w/x pipe
    *blue apikol snub mount
    *apikol red transmission mount
    *034 engine mounts
    Maintenance :
    *jhm adjuster sprockets
    All new guides (updated aluminum center guide)
    All new tensioners
    New chains
    New valve seals both sides
    New head gaskets both sides w/new head bolts and cam bolts
    New oil check valve
    New fuel pump
    New fuel filter
    All o2 sensors replaced
    All new coil packs & ngk platinum plugs
    New starter
    New waterpump & thermostat
    Jhm belt tensioner
    My car never burned any oil to my knowledge. I used mobil 1 every 4500 miles. Never had start up rattle that everyone else experienced. Think 20k is a fair price considering all the mods and maintenance put in. Here is a link showing most of the process
    http://www.audizine.com/forum/showth...t-back-to-life
    05' B6 S4 Brilliant Red 6MT: JHM 93 Tune ● JHM Ported Manifold w/spacers ● JHM Lightweight Pulley ● JHM Lightweight Flywheel ● JHM STG3 Clutch ● A.W.E. Catless 2.5" Downpipes ● Custom 2.5" Corsa Non-Res Exhaust w/x-pipe ● KW V3 Coilovers ● Stern Adjustable Upper Control Arms ● JHM Short Throw Shifter
    00' B5 A4 2.8 5MT: Gone
    Nov 11 2008
    Oh & front & tear main seals have been replaced too. Also have stock exhaust if the corsa exhaust is too loud. And the car has 19" oettinger rz wheels
    Jan 29 2010
    north ga
    Haha, your price is actually pretty laughable. I think the guy who bought mbgt72's old Supercharged B7 only listed it for like 15k and it had tons more mods.
    I've got nearly the same mods on my Avant, PLUS headers, but no JHM manifold. I doubt I'd be able to get 14-15k. $20K is beyond reason. Mods add maybe 50% value when on the car, and that is being generous
    Nov 11 2008
    Believe his car had bad oil consumption if im not mistaken. My car doesnt have that issue. Only thing that isnt new on my car is alternator,power steering pump and ac. Everything else is new
    Nov 11 2008
    Tons more mods? Only thing i dont have is blower & headers
    Nov 11 2008
    Also doubt his car had as much maintenance items addressed
    Jan 29 2010
    north ga
    I uaed his car as an example. That car had $25-30k of mods on it alone. Or it could have gotten a different motor for a couple thousand and been good to go.
    And yes there are more possible mods: Coils, adj control arms front&rear (pretty sure you sold both of those), subframe bushings (front&rear), diff mount, sway bar and links, jhm oil cooler, snub bracket, B7 console, nav, aftermarket wheels or seats, flat bottom SW, big brake kit, limited slip diff, 4:1 center diff, he'll limited slip front diff, longer 6th gear, HD heads, roof rack, plus I'm sure there's more I've missed
    My point is mods&maintenance only adds so much to the value of the car. Usually it is just a tiny percentage of what the person spent getting it there. That's why people often take mods off before selling to recoup some of their investment (exactly like what you've been doing). $20k for a B6 with over 100k miles isn't gonna happen. Even if it had a SC or nitrous, airride, fancy wheels, and all maintenance it's not very likely
    Nov 11 2008
    Buying another motor doesn't mean it wouldve solved an oil burning issue. Wasnt there a guy who went through like 4 used motors from salvage yards? Im not selling a car with oil burning or chain rattle. "If" someone were to buy it they shouldn't have to worry much about anything.only driven about 2-3k miles so far after finishing it up
    Nov 11 2008
    Kudos to everyone whos put more time & money than i have into their cars and sold less than 15k. I just cant see myself doing it. Always cheaper s4s out there but doubt theyd have everything replaced as my car does.
    Dec 07 2009
    East Coast
    "better on gas and draw less attention" - pshsh nonsense, gas is cheap these days and I wish mine would've attracted more attention. Keep this beast and sc it. There're a lot more interesting mods left on the table to make you feel excited again
    Forget the B8, keep the V8!
    Senior Member Three Rings cmd4's Avatar
    Jan 09 2010
    asheville
    GLWS….love the b6 platform, but with rs4 and similar mileage not breaking 20k or a avant i don't see it happening
    RS4 mugello blue,Ti-Curing the itch
    04-Cobalt Allroad 78k 6mt- Car seat duty
    b6 s4 avant blk/blk-57k 6mt Gone
    DD -03 7.3 pwrstrk 6spd 200k and counting
    85 fj 60 lt1 and nv4500..Gone
    96-993 C4S…Gone
    78-fj40-smb350…alum tub,aussie 4spd,orion t case ,detroit locked
    97-40th fj80 on 33's and arb front
    Nov 11 2008
    Quote Originally Posted by Mr.Wrong View Post
    Lol kinda want an mk2 TTS
    Established Member Two Rings The Guvna's Avatar
    Nov 28 2015
    Audi S4 Avant
    VA
    Shit, my nog blue avant/alacantra seats, 6 speed with 106k miles on it and fully bagged/exhaust/mounts as well as other things must be worth at least $30k!
    Just kidding, GLWS!
    Audiless :(
    Nov 11 2008
    meh, avants are slower and over-rated. just my opinion. like i said just a feeler for someone who wants and s4 with nearly everything as far as maintenance and mods addressed.only major parts that aren't new is the alternator and a.c. pump and i hardly used mine so it should still be good for a while.But if this too steep for potential buyers then good luck taking a chance spending 8~15k on an undocumented b6/7 s4.
    Oct 02 2005
    The Moon
    Nice car, but it really is very overpriced. Honestly, 11-13k is to be expected assuming it's clean.
    Don't take an offensive approach to the comments, market dictates value, not what you spent on it.
    Veteran Member Three Rings Brandon K.'s Avatar
    Apr 17 2016
    2017 Golf R, 2018 Q7 3.0T, 1991 Saab 900T
    Vancouver WA
    I am not going to suggest a value, but it's probably worth about what a high end/semi-exotic used car dealership would ask for a bone stock one with similar miles... privet party, records & Quality mods = trust for the dealer markup
    Nov 11 2008
    Quote Originally Posted by p3u View Post
    i hear you on that
    Nov 28 2015
    Audi S4 Avant
    VA
    Quote Originally Posted by S4orgy View Post
    Over rated? More room, more rare = over rated? Each to his own, but that's about the silliest comment I have ever heard. And who cares if its slower, the B6 S4 isn't a race car, no matter how much money you pump into it!
    GLWS, I hope you get some of what you put in buddy!
    Audiless :(
    May 28 2012
    2013 Allroad - 2007 RS4 - 2000 A4 1.8T Quattro
    San Diego/CA
    I am sorry to say that you will never EVER EVER get nearly what you are "Feeling", no offense.. if its a feeler, you have already felt it. Delete the post and keep the car.
    Mods.
    *jhm 93 oct tune
    *jhm short shifter
    *034 engine mounts
    Maintenance :
    All new tensioners
    New chains
    New oil check valve
    New fuel pump
    New fuel filter
    New starter
    Jhm belt tensioner
    Moyzes
    B7 RS4
    B8.5 All Road
    B5 A4 1.8T QT 5MT
    Veteran Member Four Rings Silver Streakin's Avatar
    Mar 05 2004
    B8 S4, 17 Expedition EL, 2009 328ix coupe
    NoVA
    Why aren't the coilovers listed?
    2011 S4, 6M, BB/panda, Sport diff, ADS, B&O | UniTronic stage 3 Dual Pulley | MercRacing HX | RocEuro intake | AWE Track & DPs resonated | H&R c/o w/Bilstein B8 rears| 19" VMR 710 & 19" Peelers | 034 trans insert | AK brace | CR15 bar | DEVAL CF Diffuser
    SOLD 2007 S4 DTM, Phantom Black Pearl, manual | JHM | FI | H&R | VMR | 034
    RIP 2001.5 A4 1.8TQMS, Silver/Ebony | APR stage 3 | STaSIS Tracksports | StopTechs
    SOLD 1995 90
    Dec 07 2009
    East Coast
    Quote Originally Posted by Silver Streakin View Post
    LOL
    Dec 02 2007
    2020 Ford PIU, 2017 D675R
    DC/MD/(VA)
    whatcha getting as a replacement?
    2015 B8 SQ5
    Click Here
    Past
    Senior Member Three Rings Der Typ's Avatar
    Mar 04 2015
    Clawson, MI
    I am more scratching my head about him going through all the trouble with the timing chain process and now he is losing interest in the S4 game...
    Veteran Member Four Rings Blackstallion's Avatar
    Sep 22 2009
    Can always quiet up your exhaust if you want to draw "less attention"
    Sep 22 2009
    Here's a comparison - I picked up my 2nd b6 s4 about 5 years ago with a decent amount of mods including a new engine...
    2005 S4 Brilliant Black/Black
    Roughly 10k miles on new engine
    80k on the rest of the body
    Fresh clutch, fluids, belts and misc. parts
    10k JHM center diff
    JHM lightweight pulley
    Stoptech ST60 Red
    Stasis Ohlins SL coilovers
    Stern Adjustable control arms
    Magnaflow Exhaust
    Billy Boat DP
    Piano Black Interior Trim
    RS4 Rear Sway
    Hartmann R8 reps 19x8.5
    16k USD shipped 5 years ago
    Nov 11 2008
    Were the valve seals done?did their car have all guides/tensioners done w/jhm sprockets, & upgraded aluminum center guide. Did they have brand new starter,ignition,fuel pump,water pump, new head gaskets with new head studs. Did they have all new coilpacks and plugs, &all four o2 sensors at once.atleast mine is documented ive replaced /addressed too many future issues during the time it was down. And have put 2k miles on her currently. Shes a beast
    Jun 07 2014
    phila pa
    i have to side with s4orgy here. its not about the performance work as much as the labor cost savings for doing all of the maintenance work. good luck buying a 6-7k s4/allroad and dumping in a ton of money on parts and then paying for labor. obviously this does not take into account the people who can do work themselves or have access to very affordable parts.
    edited because posting from a phone sux.
    Sep 22 2009
    Nevermind - goodluck waiting for the right buyer. This is a 12 year old car that descends in value day by day...
    Nov 11 2008
    Quote Originally Posted by rgtorque View Post
    i have to side with s4orgy here. its not about the performance work as much as the labor cost savings for doing all of the maintenance work. good luck buying a 6-7k allroad and bumping in a ton of money on parts and then paying for labor. obviously this does not take into account the people who can do work themselves or have access to very affordable parts.
    thank you dont mind him he's just trolling
    Veteran Member Four Rings SuperAvant's Avatar
    May 30 2007
    MA
    Put it up for sale and see what happens. The market has spoken here. Perhaps you can pull one over on someone who doesnt understand American currency. But if you can more power to you.
    2014 R8 V10 - Gated
    2005 S4 Avant 6 Speed - JHM Stuff
    2017 TRDoffroad 4 Runner
    Veteran Member Four Rings james12lucy's Avatar
    Jul 04 2015
    North America's only B7 Chump Car. 2006 2.0T A4, fully gutted, custom Loose Stones Racing Roll Cage,
    Toronto Ontario
    S4Orgy, I appreciate the time and effort you put into your car, I really do.
    Having said that...
    Clicky Linky
    This is an RS4, with similar mileage, and costs $22k Canadian ($16,404 USD). Might want to adjust your valuation.
    Why aren't people buying Canadian RS4s?
    B7 Avant, 6MT, Quattro - Brilliant Black: JHM 93 Octane Stage 2 tune, APR HPFP, S3 Injectors, JHM Test Pipe, Stasis Catback, R8 coils, 034 TIP, Custom CIA, 18" VMR 710, Podi Digital Boost Gauge, RS4 rear sway bar, RS4 grill, Eurojet Billet VC, 42DD catch can, Ohlins SL Coilovers w/ Hyperco springs, OEM Bi-Xenon retrofit, GFB DV+, Brembo 18z.
    Veteran Member Four Rings sandspeed's Avatar
    Mar 13 2007
    05 S4 Avant Abt AS400 clone, 14 SQ5
    Sunny UK
    Quote Originally Posted by james12lucy View Post
    Having said that...
    Clicky Linky
    Because they would have to import them and don't want to deal with asking Audi for a letter saying it's the same as an American one.
    -Tim
    Senior Member Three Rings scottkollig's Avatar
    Nov 12 2015
    Delray Beach, FL
    Between this pricing and this thread (http://www.audizine.com/forum/showth...w-s4orgy/page3) I would be extremely careful. GLWS, but that is way above market value.
    The most dangerous phrase in your vocabulary is "good enough".
    DTM 08' S4
    Jan 14 2009
    Audi's
    Pricing seems all over the place. Considering you have done the timing and valve stem job that should be worth a lot for someone looking to own one of these beastly grocery getter's.....
    https://www.cars.com/for-sale/search...rchSource=SORT
    Given the amount of maintenance / mods you have into it wouldn't be worth selling for less than 15+ range just have to find a buyer that wants a modded example to save some dough.
    Nov 11 2008
    Quote Originally Posted by scottkollig View Post
    Yes post the thread where i shipped coilovers to the guy even after he bashed my name on threads and acted like he didnt get them and got a charge back from paypal. So now i owe paypal 1175, out $160 i payed to ship to him and i text him the day i shipped them and he ignored me, and he has the coilovers of course. Its ok matthew karma will come back around.
    Sep 22 2009
    Quote Originally Posted by SuperAvant View Post
    Haha maybe 5+ years ago this would attract a buyer north of the boarder - one would be close to 30k bringing this back to Canada today with exchange rate and fees....
    Veteran Member Four Rings Fourplay's Avatar
    May 01 2010
    Atlanta
    Having said that...
    Clicky Linky
    They are. Mine was in Canada. I paid marginally more than the OPs asking price for a mint '08 RS4 with 78k miles.
    For the OP: https://en.wikipedia.org/wiki/Endowment_effect
    You'll either have to drop the price by 5-7k or keep the car, it's not worth what you're asking.
    2005 Ferrari F430
    2007 RS4 Daytona Grey | 2008 RS4 Mugello w/Ti Package | 2007 RS4 Avus Silver (ex-Audi Corporate) | 2008 RS4 Avus Silver w/Exclusive Package
    B6 S4 Avant 6MT Dolphin Grey
    B5 S4 Avant 6MT Laser Red Stage 3+
    B5 S4 Sedan 6MT Silver Stage 1
