Results 1 to 3 of 3
    Junior Member Two Rings
    Jul 16 2014
    United States
    MAF code but abnormal symptoms
    Hi all,
    My 1.8t is throwing a 0102 cel for the MAF, but my idle seems fine.
    I don't feel a loss of power either. Occasionally the idle will dip by 100rpms for a moment but then is fine, but that has happened for a while.
    When the CEL first came on I noticed the car kinda surge under acceleration. It has now done this a couple times, and is accompanied by the esp light coming on.
    Cleaning it with MAF spray didn't have any effect.
    running it unplugged feels no different than running it plugged in.
    Any ideas?
    Apr 03 2016
    Up North
    That code is low output. I think you have a bad MAF, but obviously not bad enough to cause a real difference when unplugged (yet).
    MAF cleaner is meant for hot wire MAFs, not the hot film MAFs in these cars. I wouldn't count on it fixing a MAF issue. If you have access to VCDS you can log the MAF output and see what it is. Compare that data to what is given in the many threads here about bad MAFs as standard. That would give you an indication of if it is truly the problem. Anything other than empirical data will be guessing.
    Speaking of guessing, if you have a oiled air filter like a K&N then I would think that your MAF needs replacing due to oil contamination. When some people oil them, they think more is better and that extra oil ends up in your MAF. When I bought my B6 it came with a box that had two dead MAFs and half a can of MAF cleaner. I wasn't surprised when the installed MAF died two weeks later. I didn't even open the airbox before buying an OE replacement filter, knowing full well that I would find a dripping K&N inside as the source of the issues. Sure enough I was right... No issues since with a dry filter.
    Mar 07 2014
    Any fix on this
