Results 1 to 6 of 6
    Aug 19 2016
    valencia/CA/USA
    SoCal Bi xenon leveling help please B8 09 A4 sedan
    I really need some help with this retrofit. Let me first say, I am doing the full retrofit of the bi xenon with the leveling sensors and range finder NOT just the headlight with the kufatec adapters and then adjust manually.
    Where I am stuck is I need to get the rear leveling sensor installed and because it goes through the rear end suspension on this model either the rear end subframe needs to be dropped or the gas tank to get out the long bolt that the rear leveling sensor attaches to. Has anyone actually installed the kufatec rear leveling sensor on the B8 model? Other models have very different attachments and are not the same and much easier. I someone that has a shop willing to unbolt the rear subframe and has a spring compressor to get it done. The local Audi shops won't touch it and my Indy guy won't do it either. I NEED HELP PLEASE. THANKS
    Paul
    Aug 19 2016
    valencia/CA/USA
    Anyone?
    Aug 19 2016
    valencia/CA/USA
    Not one person has a SoCal shop recommendation?
    Aug 19 2016
    valencia/CA/USA
    Bump
    Senior Member Three Rings Jon_90's Avatar
    Apr 27 2016
    2001 mustang
    Southern California
    Only tuner shop i know of what that might be of help is Impex motors in temple city off the 10 freeway and valley and Baldwin i think
    Active Member Two Rings LGHT's Avatar
    Jun 07 2018
    CA
    You can try DDM Tunning in HB. They might be able to help. They also have a guy that does installs who owns an audi. Just ask for Francis.
