I really need some help with this retrofit. Let me first say, I am doing the full retrofit of the bi xenon with the leveling sensors and range finder NOT just the headlight with the kufatec adapters and then adjust manually.
Where I am stuck is I need to get the rear leveling sensor installed and because it goes through the rear end suspension on this model either the rear end subframe needs to be dropped or the gas tank to get out the long bolt that the rear leveling sensor attaches to. Has anyone actually installed the kufatec rear leveling sensor on the B8 model? Other models have very different attachments and are not the same and much easier. I someone that has a shop willing to unbolt the rear subframe and has a spring compressor to get it done. The local Audi shops won't touch it and my Indy guy won't do it either. I NEED HELP PLEASE. THANKS
Paul
