Results 1 to 9 of 9
    May 02 2016
    RI
    Tensioner Bounce After Alternator
    Hey everyone, just recently changed my tensioner and alternator becuase of the usual clutch pulley seizing.
    The rattling went away however, the tensioner is still bouncing just as much as before. My dampner pulley looks like its bouncing a bit but may just the outter rim. Ill try and grab a video.
    I do get a vibration in the car at idle. Not sure where to go from here...i appreciate any help...
    Sent from my LG-H811 using Audizine mobile app
    Apr 15 2014
    Ottawa/Gatineau Canada
    My tensioner bounces as well....I wonder if this is normal.
    2004 A4 Avant Quattro. (H&R springs, S100 Nav unit, Neuspeed Cat back, Torque solutions Snub mount, Thor Skid Plate, APR Stage 1, 18" S4 Rims, 2X Podi / Oil Press / Oil Temp / Boost/VAC, Full LED interior, Backup Camera/Screen, Upgraded 2.0 Coil Packs, Vag-Com, B7 Center console/B7 Hand Brake, B7 Aero wiper arms B7 rear headreasts,APR Carbonio intake, Fan washer sprayers,
    2014 VW Tiguan. (bone stock)
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    Thats the tensioner allowing for play in the belt - its doing its job.
    2019 SQ5 Prestige
    May 02 2016
    RI
    Thanks for the replies, hope its normal never seen it on any other car. even my 1.8 gti doesnt do this. Ill keep my eye on things seems to be running ok for now.
    Veteran Member Three Rings 5ktq's Avatar
    Aug 15 2016
    Western Canada
    A non-seized overrun clutch should make it bounce less as I understand it - though my B6 (with unknown condition, likely seized clutch) bounces a lot more than my GTI with a fixed pulley, go figure...
    May 02 2016
    RI
    Quote Originally Posted by 5ktq View Post
    Yeah exactly not really sure why it bounces just as much. My gtis tensioner barely moves
    Jan 24 2010
    Paramus,NJ USA
    The tensioner could be worn it only a spring.But they do bounce.If it bouncing alot it possible its worn and need to be replaced.But normally you would have a squealing belt to go with it due to lack of tension.
    Ziddy Autowerks
    May 02 2016
    RI
    I changed the tensioner when i did the alternator
    Veteran Member Four Rings MacFady's Avatar
    Aug 10 2011
    330i ZHP
    Prince Edward Island
    Without a video a little bounce sounds normal as you describe, nothing to do with your vibration.
